Question about Whirlpool GY398LXPS Electric Kitchen Range
Replace thermistor 9759944 - Whirlpool GY398LXPS Electric Kitchen Range
My stand alone Kenmore elite 3 cycle under counter ice maker has stopped making ice. is there a reset procedure?
This is what I read somewhere....
ok, then this means that one of your thermistors is shorted. There is a chill plate thermistor mounted to the bottom of your silver plate where the ice is formed, and there is a white thermistor mounted to the right side wall inside your bin. You can disconnect the chill plate thermistor and run a cycle to see if it will run without being connected. If the error goes away, you can leave the thermistor disconnected or replace it, either way the unit will continue to work.
If you disconnect the chill plate thermistor and it still doesn't work, then you need to replace your bin thermistor, you can't just disconnect this thermistor to get the unit working again.
May 02, 2016 | Kenmore Refrigerators
Fix the thermal fuse
Teresa:
It's a thermal fuse, (in this case it's a thermistor) and like any other fuse that has blown, it needs to be replaced. (The thermistor doesn't cost much... a few dollars at the most.) To replace the thermistor, the bottom of the waffle iron will have to be removed, and the thermistor de-soldered from the wiring (make sure that you note which way the thermistor connects to the wiring... you don't want to solder the new thermistor backwards!). Take the thermistor to an electronics shop and buy another identical thermistor. Solder the new thermistor to the wiring the same way the old thermistor came out. Reassemble the waffle iron, and don't leave the waffle iron on when you're not making waffles!
Nov 25, 2014 | Waring WMK300 Pro Belgian Waffle Maker
Freezer works refrige doesnt
Sounds like the thermistor is bad. Several ways to test.
1: Place the end of the thermistor that is located inside the refrigerator into a glass of slushy water and read the ohms resistance on the plug end which is located on the back of the refrigerator. Google the ohms resistance chart for Dometic thermistors and compare your readings to the chart. If they are not in range then the thermistor is bad and needs to be replaced.
2: Unplug the thermistor from the circuit board. It will be the harness that has only two wires going into a hard plastic plug. Leave it unplugged for 24 hours and check the temp inside the refrigerator. If the temp has dropped then the thermistor is bad and needs to be replaced.
To replace the thermistor remove the thermistor sensor end from the plastic clip. Remove the plastic grommet from the back wall of the refrigerator. Tape the new plug end to the sensor head of the old thermistor and gently guide it through the hole. Once the taped head/plug passes through the hole you may complete pulling the new thermistor through from the back side. Only pull enough to allow you to plug the new thermistor in. Un-tape the plug end from the head and plug the thermistor in to the circuit board. Reinstall the cover over the circuit board and reinstall the access pane. There will be some sealing putty on the old thermistor harness. Remove that and gently press it back into the hole around the new thermistor harness inside the refrigerator and reinstall the plastic grommet. Install the sensor end into the plastic clip and install the plastic clip between the first and second fins. The higher up on the fin the colder the temp will be inside the refrigerator.
Apr 12, 2014 | Dometic RM2852 Refrigerator
Ir7095 error code E000004-0001
If you have more than 200 000 prints need to be replaced: Fixing assembly 230 V......... FM2-0174
Inspect thermistor and switch on FIXING UPPER FRAME ASSEMBLY
Oct 09, 2012 | Office Equipment & Supplies
My dryer shows hE code what does it mean its a samsung
Samsung Dryer Fault Codes ts Thermistor short Check for restricted vent. Replace thermistor to Thermistor open Check for restricted vent Replace Thermistor do Door Open Check connections. Replace door switch. FE Power Source Frequency error Check power source dF Door circuit failure Check wiring to door switch. Replace door switch hE Heater error Restricted vent. Replace thermistor. bE Button Error Check and / or replace PCB od Over dry Sensor Bar open. Adjust time up excessively. Et eeprom failure Replace Eeprom
hE Heater error Restricted vent. Replace thermistor. Heater error
Clean vent and replace thermistor.
Clean all vents from outside all the way to the blwer housing. If you dont get all the lint it will cause this to happen again.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung WF203ANW Front Load Washer
I have a whirlpool gold oven that after cleaning the door was locked, after opening door would not bake. Replaced the thermostat (tod) {8300802}that was bad but now the keypad just beeps. Ok, so I replaced...
We are sorry to hear of the problem with your Whirlpool oven. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your oven.
Apr 14, 2017 | Whirlpool GW395 Gas Kitchen Range
Replacing Thermistor on Kenmore 11078062801 dryer
Disconnect power then remove the screws securing the rear panel to the cabinet as shown.
Once the rear panel is off, you'll see the exhaust along with the thermal fuse on the blower housing as shown.
Simply unscrew the thermistor if it needs to be replaced and screw the new thermistor in place then transfer the wires from the old thermistor. If your dryer has the inlet thermistor that needs to be replaced, do the same as the outlet thermistor above.
Nov 06, 2010 | Kenmore Elite Oasis ST 7806 Dryer
Dryer shuts off after 5min (code E1)
Well the error E1 message indicates that the thermistor is defective and needs to be replaced.
Try unplugging the unit for a few minutes got rid of the error, but lately the temperature just hasn't been hot enough so the clothes don't dry. You must need to replace the thermistor for full working of your dryer. you may please follow the below steps to know how to change the thermistor -
1. Locate the thermistor on the top right hand side of your dryer. This will be a small platelet with a chip and wires coming out of it. Use your screwdriver to remove the two screws holding the thermistor on the unit.
2. Unplug the wires from the thermistor.
3. Plug the wires into your new thermistor. Replace the thermistor on the dryer and the screws holding it in place.
4. Replace the back panel of the dryer and plug your dryer back into the wall outlet.
5. Push your dryer back up against the wall and turn it on again.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE3 dryer keeps stopping indicating an E1 error. The model number is 110C82822100
Post comments for further help or information......
Good Luck!!
Aug 28, 2010 | Kenmore Dryers
Canon ir 2016j
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
Whirlpool GY398LXPS Electric Kitchen Range Logo
19 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
