Question about Mitsubishi CS-40503 TV
Mitsubishi CS-40503 TV previously had discoloration in the corners and lines at the top of the screen. Now I have no picture at all. Is it worth trying to fix?
    Sergeant:
    Champion:
  • 255 Answers
No picture?do you see a white horizontal line in the mid?or black out?
its up to you if its really worth fixing. if its really old then ,i think its time to buy a new one, if not try comparing the cost.
Posted on May 18, 2009
CS-40503 takes about 10 minutes for the picture to appear once the set is turned on (sound comes on immediately)....when the picture does appear, it's dim for approx. 5 seconds then comes up to full...
IF THIS SET HAS PIP (PICTURE IN PICTURE) THAN I'D SAY THE PIP MODULE IS GOING BAD. YOU CAN REPLACE IT OR GET THE BYPASS PLUG FOR IT. IT JUST PLUGS IN.
Dec 10, 2009 | Mitsubishi CS-40503 TV
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Sep 28, 2008 | Mitsubishi CS-40503 TV
Mitsubishi Model CR3515R White Gray lines cause picture inversion.
Your having trouble with the vertical sync/deflection circuitry. Probably a driver since it clears up after it gets warm. Could be as simple as a cold solder joint but it's not something you can do yourself unless your a tv repairman.
Sep 24, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS 40503
it is repairable and can be fix,,
Jul 30, 2008 | Mitsubishi CS-40503 TV
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS 40503 TV
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Oct 11, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
