Venta Airwasher VS 207 3.7 Gallon Humidifier
Problem for Venta Airwasher VS 207 3.7 Gallon Humidifier
Humidifier not working
By daisygolden1 on May 18, 2009
My humidifier is not working. The tank is full, but the mist will not come out. If I pick up the tank and put it back, mist will come out, but only for a short time. I cleaned and changed the filter-did not help. I have the humidity set to continous. I have had it for a year and run it cotinuosly
Solution #1
posted on Jul 03, 2009
Not Rated)
rickpepper
Rank: Guide
Rating: 75%, 1 votes
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
Was this helpful?
Yes
No
Popular Solutions for Venta Airwasher VS 207 3.7
Questions and Unsolved Problems for Venta Airwasher VS 207 3.7
Do you recommend Venta Airwasher VS 207 3.7 Gallon Humidifier?
Answer
Answer
I have a venta 205. A half hour after I start it the light begins to flash and it stops giving... (More)
Answer
Venta-sonic VS 207 humidifier. Turns on but the display just flashes lights. I had it stored all... (More)
Answer
I turn the machine on and the light flashes red and nothing happens, I don't have a manual to... (More)
Answer
Venta-sonic VS207 humidifier display blinks and no controls work. Have tried to clean as instructed.... (More)
Answer
I have had my Venta 207 humidifier for two years but it has been humidifying very little recently. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta Airwasher VS 207 3.7...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
