Question about Tecnik TKL9260 Front Load Washer
Roper Washer The washer is spinning but the top of the agitater is not? What is wrong with it and how do I fix it
  • 291 Answers
The gears in top are stripped out need replacing, take cap off agitator and take out bolt pull agitator out ..pull top part agitator off and replace gears
Here is what the gears look like for the top part of the agitator
top part of agitator
bottom
Posted on Oct 18, 2007
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Agitater
If the washer will spin but not agitate , then the transmission needs replacement. You should probably get an estimate from an appliance tech to see if it is more economical to replace the part or the machine.
May 02, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Estate top load washer
it you pop the top on the agitater you will see 4 gears called dogs, remove the 7/16 bolt upll the top half of agitater out and replace the dogs,you can get them at your local appliance part store,let me know how you do-mike
Oct 27, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Roper washer
my agitator will not turn
Aug 21, 2008 | Roper RAS8445KQ Top Load Washer
Roper washer, agitater stripped?
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Aug 06, 2008 | Roper RAX7244KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Tecnik TKL9260 Front Load Washer Logo
115 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
