Question about Samsung Televison & Video
How do i setup my tv through surround sound without a cable box?
I am changing from a cable box to just basic cable and I have surround sound. my tv is hung on the wall and the cable was run through the wall into my cable box. now that I am getting rid of the box, the cable folks said I have to plug the cable directly into the tv. is there a different solution? or do I need to now take my tv off the wall, fish the cable back through the wall to the cable outlet and connect to the tv itself? please help. Thanks, Janet
  • 905 Answers
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Posted on Dec 27, 2013
SOURCE: No surround sound when watching TV
hdmi can only pass pcm 2.0 digital for the separate cables you may try to switch them to another output from the monitor to the receiver or if you can get your hands on a spd-if cable (one single fiberoptic cable that will go as high as 5.1 dolby surround)
Posted on Feb 01, 2008
  • 138 Answers
SOURCE: Sky remote code for JVC GM-P420E
Go to www.remotecentral.com
Posted on Aug 19, 2008
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
SOURCE: Black Screen
I have a Samsung HP5053 Plasma Flat Screen and there was a cracking noise and the picture clarity changed to dull. Does anyone else have information on recalls for this TV?
Posted on Sep 23, 2008
SOURCE: Sony LCD Problem...
My t.v. just went out as well...how convenient because my warrenty just went out a couple weeks ago. From what I have heard from many different repair people that the problem is with the power supply board. Since I also bought the tv from sears here is my plan. I puchased the new board through sony which is only $150. I am going to swap it out with the old one and pray for the best. I have talked to sears about getting the buyer protection for the tv after a year after i purchased it and they will charge you a higher price for the warranty as long as the tv is still functioning. If all goes well with the repair i will get sears on the phone instantly because a service guy has to come out and verify that it functions properly.
Posted on Oct 10, 2008
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
No sound with cable tv- AM/FM works ok
First, check all the connections to the receiver.. Make sure everything is plugged in where it should be.. Also make sure, that when you are on TV/CABLE that the surround sound is selected and that "headphones" is not.. Also check any other modes that may have been changed, (IE digital input, 5.1 channel, etc...)
Apr 05, 2008 | Yamaha RX-V661 Receiver
I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the 1611..........Johnmoondancer@hotmail.com
Mar 06, 2011 | Audio Players & Recorders
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Televison & Video Logo
194 people viewed this question
Jerry Greenberg
Jerry Greenberg
