Was out riding and bike kept going in and out of powerband and then it just went out competely and slowly came to a stop and made a grinding niose and wouldn't start agian no smoke though
SOURCE: while riding my yz 125 it just died and won,t kick up again
Please rate the solution as a "FixYa" if able. Thanks!
SOURCE: 1997 yamah yz 125 lots of white smoke comeing out of pipe
How much was it smoking previously? Too much smoke (oil) is a whole lot better than not enough smoke (oil). If you are mixing the oil and gas then cut back on the mixture. Obviously it is out of balance. Put 1/2 gallon of raw gas in the tank to cut the mix. After a tank or so you should get the balance back.
You need a new shift shaft and probably need a new shift lever due to the bad splines. You can try the JB Weld but I suggest that you go ahead and drill the lever an shaft then put in a cold roll split pin from the hardware store. You have nothing to loose since the shaft and the lever are already toast.
Please rate this solution. Thanks!
SOURCE: bike boggs down no powerband rm 250
i have a 92 rm 250 an i just had it fully rebuilt an it laggs in power band an splutters an feels guttles
