Question about Cuisinart DCC-100 Coffee Maker
Intermittant coffee brew on cuisinart dcc-100
Turned on the coffeemaker, start the brew cycle. It sounds like the water begins boiling and the coffee starts flowing in to the carafe but it then stops and waits for a little while before it starts brewing again. the cycle repeats over and over and it takes over a hour to finish. After checking the warming tray, it was cold. I suspect a electrical problem. Did watch the power light and it never went off during the brewing cycle.
Thanks in advance for any help.
Bill
SOURCE: Cuisinart DCC-2000 Coffeemaker
Thanks!  That's good to know.  I found my manual, and decided we hadn't cleaned it recently.  I filled the reservoir with 1/3 white table vinegar and 2/3 water.  That didn't seem to do anything, So I took a syringe and an IV catheter, (it helps to be in health care) and squirted some of this down "sprinkler".  We let it sit a couple of days and every now and then, turned on the coffee maker, and in a couple of days it went.  We put it through again withthe same solution (to clean calcium deposits) and then with water a few times to get rid of the vinegar smell.  It's been working well for two days now.
Posted on Apr 29, 2008
SOURCE: Cuisinart DCC 2000C
We have the same intermittent problem with the on/off switch on our DCC 2000C......don't know if the switch is bad (we hear it click when turned on) or if the water pump is intermittent. Either way, the end result is no coffee and concern about a potential fire. Today, after reading a post by a DCC 1200 owner with the identical problem, I called 1-800-726-0190 and spoke with a young man who was most helpful. Although, we cannot locate our proof of purchase, we believe the serial number indicates manufacture within the warranty period. He said we will receive a replacement in 7-10 days and then we must return the malfunctioning unit in the same box along with a $10.00 check. We'll see how it goes and post again if it doesn't happen as I've described.
Posted on Oct 07, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
  • 85 Answers
SOURCE: Cuisinart DCC-1200 brewing temperature
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
Posted on Jul 08, 2009
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
Got this coffee maker from a buddy. had been sitting for a while,ran lots of water and 2 cycles of vineger and water though without the filter to clean out debris in resevoir. still getting quit a bit in...
You may find this a useful site in the future:
http://www.cuisinart.ca/cuisinart_product.php?item_id=63&product_id=58&cat_id=2
Your Instruction Booklet:
http://www.cuisinart.ca/pdf/ibs/en/DCC-1200C_en.pdf
It is likely that calcified deposits are gradually breaking away as you now use the coffee maker. Is your Self Clean light flashing? Instructions on decalcification and cleaningh begin on page 5 of your booklet.
To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. For your problem, let the vinegar solution sit in the reservoir for 30 minutes to an hour before beginning the cleaning cycle.
Press the Self Clean button. When the self clean light glows, turn the coffeemaker on by pressing the ON button. The self clean light will shine steadily. The coffeemaker is now in Self Clean mode. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, the coffeemaker will shut off. Turn the coffeemaker ON to see if the Self Clean light continues to flash. If it does, turn it to OFF and then repeat the cleaning procedure with a fresh solution of vinegar and water.
If the Self Clean light no longer flashes, turn the coffeemaker to OFF and then run one cycle of fresh cold water through the unit before using the unit again to brew coffee.
If you continue to see debris, unfortnately you will have to repeat until clear.
Feb 16, 2011 | Cuisinart DCC-1200 Coffee Maker
Coffeemaker will not begin brewing
For quick results please go HERE and then go HERE.
They will send you a new Coffee Pot as they have this problem a lot with first year coffee pots. a68c472.jpg
Apr 17, 2010 | Cuisinart DCC-2000
I lost my manual on how to use the self cleaning on my cuisinart coffee machine
Decalcification
Decalcification refers to the removal of calcium
deposits which form over time on the metal
parts of the coffeemaker.
For best performance from your Brew Central
Thermal™ Coffeemaker, decalcify the base unit
from time to time. The frequency depends upon
the hardness of your tap water and how often
you use the coffeemaker. The flashing Clean
light will indicate when you should clean your
coffeemaker.
If the Clean light begins to flash when the
coffeemaker is turned on, it is telling you that
the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir to
capacity with a mixture of ¹⁄³ white vinegar and
²⁄³ water. Press the Clean button. When the self
pressing the on/off button. The Clean light will
shine steadily. The coffeemaker is now in Clean
coffeemaker ON to see if the Clean light
If the Clean light no longer flashes, turn the
Notes on the Clean F unction
Pressing the Clean button cancels all other
settings. If it is pressed accidentally, press it
again to return the coffeemaker to all its
previous settings. Pressing ON/OFF will also exit
the Clean Mode and turn the coffeemaker OFF.
Directly from the DCC-2400STR manual
Feb 14, 2010 | Cuisinart Coffee Makers & Espresso...
Clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
Mar 29, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee pot won't turn on
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart DCC-2000
Coffeemaker getting hot but not brewing
-Tha Mp3 Doctor
Aug 06, 2008 | Cuisinart DCC-2000
Will not brew after a power failure
-Tha Mp3 Doctor````
Jul 14, 2008 | Cuisinart DCC-2000
Self Cleaning feature
I copy pasted from the pdf..
Christian.
Self Cleaning:
If the Self Clean light begins to flash when
the coffeemaker is turned on, it is telling you
that the calcium buildup is interfering with the
and 2/3 water. Press the Self Clean button.
coffeemaker on by pressing the flip switch to
ON. The Self Clean light will shine steadily.
vinegar and water.
Notes on the Self Clean Function
Pressing the Self Clean button cancels all
other settings. If it is pressed accidentally,
press it again to return the coffeemaker to all
its previous settings. Pressing ON/OFF will
also exit the Self Clean Mode and turn the
coffeemaker OFF.
Feb 03, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-100 Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
