Question about Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player
White Screen Hi, you replied to my Ipod Touch problem "White Screen", and said to remove the cover and take out the battery. I just wanting to get the information right... No problem. That the second Gen of Ipod Touch battery is pre-installed and there is no screws to remove to get to the battery. Thanks for trying, Taylor
    President:
  • 1,285 Answers
Unless you have a new battery / hard drive to put in your ipod there is no need to open it (razor & tiny flat screw driver is needed).........you are right there are no screws but this how to open it http://www.youtube.com/watch?v=NKqN_cf_vdc&feature=related.................... white screen try resetting it with itunes (press restore) feel free to rate help
Posted on Jul 08, 2009
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
Tip
How to make a high battery percentage iPod Touch 4.0
<p>By default, the iPod Touch gives you the remaining battery life with an animated image of a battery. When looking at the battery icon, you can estimate your rate is available and decide whether to load it. For a more accurate indication of your battery life, you can assess the use of the battery, which tells you the exact percentage of battery life you have available. IPod touch with 4.0 IOS software you can enable this feature in a matter of seconds. <br /> <p><br /> <p>1. Tap the Settings application on your iTouch 4. From the main menu, locate the application on the first page. By default, it appears near the bottom of the screen, indicated by a gray icon. <br /> <p><br /> <p>2. Tap "General". It has a small version of the same gray icon that you have already entered. <br /> <p><br /> <p>3. Tap the "Use" option, you can find near the top of its "General" options screen. You will see a list of relevant information about the battery life, including the extent of use since the last load and the amount of waiting time since your last payment. <br /> <p><br /> <p>4. Touch the cartoon "Battery Percent" switch on top of the screen. Tap the button to toggle between "On" and "Off" options. By switching to "On", the percentage of your battery available in the upper right corner of the screen. Tap again to "Off" position when you want to remove the percent sign, the battery of your screen. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How to delete pictures from your used iPod touch
<p>The iPod touch has a camera that can take pictures and record videos. When you make a video or a photo, the item goes to pictures stored on your iPod app for later viewing or sharing. If you use an iPod Touch, you can take photos on your iPod Touch from the previous owner. These images take up space in memory of the iPod, so you may want to remove them to make room for your own photos and video. <br /> <p><br /> <p>1. Tap on the "Photos" icon on the home page of your iPod touch and tap "Camera Roll" in "Albums". <br /> <p><br /> <p>2. Touch the square icon with an arrow to the right, at the top right of the "Camera Roll" page. Tap each photo or video that you want to delete. Each item, then select a red circle with a white tick. <br /> <p><br /> <p>3. Touch the red "Delete" button at the bottom of the screen. Tap "Delete Selected Items" to confirm the selected items to delete. <br />
on Jul 21, 2011 | Computers & Internet
Ipod touch stuck on white screen and i cant restore
Hi connect it to wall charger and charge it then connect it to pc and boot in dfu mode, if you don't know how google for it then start iTunes and restore.
Oct 07, 2012 | Apple Ipod Touch 4th Gen 32 Gb, Nice...
My ipod won't turn on
Has the battery died and when did you notice this happen? Unfortunately you aren't able to remove the battery from the ipod touch and so your best bet if it does not charge is to check your warranty to see what it covers. You may also try to have it repaired by Apple through their website.
Mar 03, 2011 | Apple iPod touch
IPod touch Digital Media Player: the screen is completly white and fozen will not p...
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod from within itunes.
May 06, 2010 | Apple iPod touch
My ipod touch wont work only has a white screen and thats it
Turn iPod touch off and turn it on again.
If the iPod will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
Nov 15, 2009 | Apple iPod touch
Stuck on black and white Apple logo screen
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode http://www.youtube.com/watch?v=bITIiGswjFI
. itune must be run on PC.
It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
This process will solve your problem 100%. I have solved same problem for ipod touch. Follow this video http://www.youtube.com/watch?v=AQk4-krrNVk
Thanks.
If my solution help you please vote up me.
May 22, 2009 | Apple iPod touch
White screen
Hi, Try resetting it first, take off the cover and completely remove your battery. Wait for like a minute or so, then put the cover back and battery. Power it up and it should be okay again. If this model has an actual button labeled RESET I would push it also(I don't believe these have them). I would think the battery is good since it is pretty new.
May 13, 2009 | Apple iPod touch
Battery will not charge .
Dear Sir, thank you for your reply re my battery problem. I found on the net a way to remove the back cover from my ipod using a plastic set square. I check the voltage on the battery with my volt meter and found it read 3.7v and 2.2v between the red/black black
white. still the pod would not work .As I was looking at this ,my computer came up with a
window showing the itunes site , I think the window asked me to choose it as the prefaired site etc I'm not sure on the precice proceedure that I followed,but the Ipod screen lit up and all seemed normal, The down side is that I lost all my music that I had
loaded on to the Ipod, Is it possible to reactivate the lost info , or must I download from
scratch, this is the second time this has happened. I would like to thank you for your
interest and I hope to avail of your service another time. thank you.
Peter.
Jul 09, 2008 | Apple iPod nano
Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
102 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
