Question about Peltor 7000 Sport Le Headset General Aviation 7004
I need a parts list for a Peltor 7004 headset.
The part that connects the headset to the boom is broken. I need a replacement part. A parts list would be helpful and where I could buy the part. Thanks
How to put peltor bluetooth into pairing mode
Normally Peltor headsets work as follows:
1.) Turn the device off.
2.) Once off, hold the on/off/mode button for 5 seconds until you hear a voice say "pairing mode"
3.) Make sure bluetooth is active on your device and search for the Peltor headset, once you find it select it.
4.) When prompted for a pairing key use 0000
that is 4 zeros.
5.) Headset should say pairing complete.
As with moth bluetooth devices remember this muse bt done within a normal amount of time so have your device ready to search by time you put headset in pairing mode will help.
Dec 22, 2012 | Peltor MT53H7BWS2 Bluetooth Headset
Peltor MT53H7AWS2 Bluetooth Headset pairing instructions
• Establish the Bluetooth link between the headset and another Bluetooth device by pressing the raise volume (+) and lower volume (-) buttons simultaneously for at least two seconds. Note that the headset must be switched off while you do this!
Some models of mobile phone require a pin
code in order for the mobile phone to identify the
headset. If this is required, enter four zeroes (0000).
This applies to all Peltor WS headsets and cannot be
changed by the user.
Nov 07, 2012 | Peltor MT53H7AWS2 Bluetooth Headset
I need the parts list, to order a broken part. Please
go to maker and search for manual by model # swampratt200~~ AAAEEE!!!!!!
Jul 21, 2009 | Telex HR-1 - Single Sided Headset with...
Can pair my h700 w my bberry storm
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 16, 2009 | Motorola Mobility H700 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
I can't sync my motorola h700c with my blackberry
2. Options -> Bluetooth -> Add Device
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
Boom Mic is broken
go to www. n1wirelss.com you can get a refurbished one for about fifty bucks with the option to get warranty
Aug 29, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Problem with Blackberry Pearl 8100
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Peltor 7000 Sport Le Headset General Aviation 7004 Logo
47 people viewed this question
Top Peltor Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Peltor Radio Communication Expert? Answer questions, earn points and help others
