Question about Dryers
Dryer modle #lde9334ace making noise
Our dryer just started to make a high pitch squeek sound everytime you turn it on could it just need a belt?
  • MIKE major May 11, 2010
    what make
  • Dennis Boxerman May 11, 2010
    In most cases, it's not the belt. It will either be a drum bearing or a tensioner pulley gone bad. If it is the drum bearing at the rear of the drum, it may be cutting into the mounting brace so I would not delay in having it looked at. A belt usually does not squeel constantly unless the load is fairly heavy. You may want to go and price a new dryer as in alot of cases, a new one is cheaper than repairing the old one. Do that before you call a repairman. Ask what the services call charges are. This will help in you decision.
    Good Luck
    Problem Solver:
  • 14 Answers
More than likely it is the belt. A simple fix is to spray some belt dressing on the belt. However, changing the belt would be the best solution. Good luck.
Posted on May 18, 2009
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post!
From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
Feb 07, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
HIGH PITCH SQUEAKING NOISE WHILE DRYER IS RUNNING.
check heatmans blog http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking also make sure the dryer belt is aligned and has tension , often an oversized load will cause belt squeek
Jun 05, 2011 | Fisher and Paykel Dryers
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 27, 2009 | Amana LGA10 Dryer
My dryer is making a high pitch squeeking noise but it still dries.
You likely have an idler wheel that is dry. The idler wheels are what supports the drum and allows it to turn freely. There may also be a belt tension problem. If the belt is too lose, it can slip on the motor, causing a squeal as well. First thing to do is pull the housing off, and see exactly where sound is coming from.
Nov 02, 2009 | Maytag PYE2300AY Electric Dryer
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
133 people viewed this question
Top Dryers Experts
