Question about Vizio XVTHB100 Headset
Bluetooth device driver - Vizio XVTHB100 Headset
Tip
How do I remove Bluetooth Drivers?
<p>When a new Bluetooth device with your computer, you generally need a driver for the work to install. Once you stop using a Bluetooth device, you may need to uninstall it before it is used by other Bluetooth devices that you still use. Bluetooth drivers and other drivers are removed from the Device Manager that is built into all versions of Windows. <br /> <p><br /> <p>1. Click Start&gt; Run. When the Run text box, type "devmgmt.msc" and click "OK" to open the Device Manager. <br /> <p><br /> <p>2. Scroll through the menu of categories device in Device Manager and find "Bluetooth devices." Expand this category by clicking the "+" sign next to it. <br /> <p><br /> <p>3. Scroll through the list of devices in this category and identify those that you do not plan more. Right-click and choose the first "Uninstall" option in the pop-up. When Windows asks you to confirm the deletion, click "Yes". <br /> <p><br /> <p>4. Repeat step 3 for all other devices with Bluetooth driver you want to delete. When finished, close the Device Manager. <br />
on Jun 26, 2011 | Computers & Internet
Windows 7 bluetooth driver drivers
As you do not mentioned the device on what you want to install.
so i can say you can check out following link:
http://drivers.downloadatoz.com/download/14174,bluetooth-peripheral-device-driver.html
Dec 18, 2013 | Samsung HM1100 Bluetooth Headset
Bluetooth perephal device problem on dell inspirion
If you want to connect a Bluetooth peripheral device to a computer, you may need to download a new driver to support it.
There are two approaches to this:
If your Bluetooth device came with a driver on a disc, you can install the driver directly from the disc.
Otherwise, simply connect your computer to the Internet and connect your Bluetooth device to your computer, then wait for Windows to install any required drivers automatically.
You may receive this message when you connect your Bluetooth device to your computer: "Windows needs to install driver software for your Bluetooth peripheral device."
Bluetooth peripheral device driver downloads are easy to locate via any search engine.
Open the CD-ROM drive on the computer and insert the driver disc that shipped with the Bluetooth device.
Wait for a moment to see if the software auto-launches, as most modern software discs do.
If the program does not launch automatically, double-click the "My Computer" icon and then double-click the "CD-ROM drive" icon.
If this does not launch the software but instead opens a file folder, look for a .exe file such as "setup.exe" or "run.exe" and double-click that.
You're looking for a Bluetooth peripheral device driver.
Follow the on-screen prompts, once the software launches, to install the Bluetooth peripheral device drivers on the disc. You may be prompted to restart your computer at the end of the process.
Letting Windows Install the Driver
Make sure Windows is up to date, as most Bluetooth drivers are included in Windows Service Pack updates.
To do this, make sure your computer is connected to the Internet, then click the "Start" button in Windows and select "Windows Update" from the program list.
This will launch an Internet Explorer window. Click the "Find Updates" button in the window and wait for Microsoft to search for available updates.
If it recommends any high priority updates, follow the on-screen prompts to install them.
Connect the Bluetooth device to the computer.
There are three ways to do this.
If you have an internal Bluetooth receiver in your computer, just make sure the receiver and your Bluetooth device are turned on and put your device within range of the computer.
If you have a USB Bluetooth receiver, plug it into an available USB port on the computer; then turn on the Bluetooth device and put it within range of the computer.
If you have another type of auxiliary cable, you may also be able to use it to connect your Bluetooth device to the computer without using a Bluetooth connection.
Watch the system tray in the bottom right corner of Windows.
You should see a notification that Windows has detected a Bluetooth device, followed by another notification that the device has been installed properly.
The installation it is referring to is that of the driver. If this does not work as expected, proceed to the next step.
Click the "Start" button in Windows, then click "Control Panel." Launch "Device Manager."
Expand the "Bluetooth Devices" entry in the Device Manager by clicking the plus sign next to it.
Find your Bluetooth device listed under this heading, right-click it and select "Update driver" from the list of options.
Wait as Windows automatically finds and configures any missing Bluetooth peripheral device driver downloads.
Hope this helps
Nov 06, 2012 | Dell Inspiron 15R 5520 USB Docking Station...
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
I'm having problems with my Bluetooth adapter or the Bluetooth technology built into my computer Sony VIO VGN-CR34GN
Please, be precise. What kind of problem do you have? Having poblem enabling bluetooth device? Or your bluetooth device enabled and you can't transfer files?
If your bluetooth device isn't enabled, go to control panel and check if device is installed correctly. (bluetooth device mustn't have yellow mark).
If your bluetooth device have yellow mark in control panel, that means you need drivers for this device. You can install drivers from your laptop's CD. If you don't get CD, no problem, download it here: http://www.all-driver.com/downloading/http://download.sony-asia.com/vaio/downloads/Original_Drivers/073Q/VGN-CR3/drivers/Bluetooth.EXE
Follow installation instructions and you are done.
Mar 28, 2011 | Computers & Internet
Thanks for your reply, but my problem is what to enter in the registration key area, to activate the driver whiz. I try numbers and letters but did not do it correct, and i need the driver for my...
If you know the model of your Bluetooth device then you can try to search the driver on the web, everything's on the web nowadays:)
By the way did you installed any driver when you first used your bluetooth device coz most bluetooth device is just plugged and play no need to install any driver, If you did not installed any driver when you first used it then that means that either there's something wrong with your bluetooth device or your pc is the one having a problem detecting the device. Try to use you bluetooth device to another computer to isolate the problem.
Feb 05, 2011 | Computers & Internet
How can i connect my nokia n70 mobile to desktop via bluetooth.plz tell me what to install the software for that.write now im with windows xp2.plz help me.i doesn't have any software regarding...
Dear Goutam,
Welcome to Fixya Support.
Generally every bluetooth device comes with driver CD.Some bluetooth drivers may preinstalled or inbuilt in windows XP with plug and play support.If bluetooth device drivers not present in windows, you have to install driver manually from CD, supplied along with your bluetooth device.
After Inserting bluetooth it pop up a message"New Hardware found",if drivers are inbuilt, operating system directly installs driver for your bluetooth device.
After Installation Go to control panel of your PC click on bluetooth icon,then click on search for active devices, if your mobile bluetooth is on pc will show your mobile name,then you have to pair your pc and mobile by supplying same pass key on both devices. So it completes pairing. Now you can share files between PC and mobile.
After installing bluetooth driver you can install Nokia PC Suit software for better management of your mobile content.
I think it solves your problem
If you have any difficulty leave a comment,we were happy to assist you.
Have a Nice Day!
Mar 27, 2010 | Computers & Internet
Bluetooth not working in lenovo y410
please check your bluetooth driver in your system.
Jan 11, 2010 | Lenovo 3000 Y410 Laptop
Bluetooth device driver is installed but doesn't recognized
From device manager, right click on the bluetooth device, and select uninstall. Then go the hardware manufactures website and download the bluetooth drivers for your product. Install/reinstall the drivers, then go to your control panel, and scan for hardware changes. It should detect the device, and want to install with the new/refreshed drivers you loaded.
May 04, 2009 | Lenovo R61 T7300 Notebook
Vizio XVTHB100 Headset Logo
Top Vizio Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Vizio Radio Communication Expert? Answer questions, earn points and help others
