Question about Garden
I can't find anyone who sells replacement Lawn tractor blades for my Ryobi tractor. Model numbe R190 with a 42 inch deck and dual blades of 21 inches each
    Sergeant:
    Champion:
  • 226 Answers
Try (tractor supply)TSC.or parts tree.com
Posted on Jun 09, 2009
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
12 hp roper lawn tractor need belt size for blade drive
take a piece of rope and run it around all the pulleys a mower shop or parts store can match it to that
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Gary
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
I NEED THE SIZE OF THE BLADES OFF A 46 INCH DECK THREE BLADE SYSTEM IT IS A POWER KRAFT LAWN TRACTOR I NEED THE SIZE OF THE LAWN MOWER BLADES
This is a part number.46 inch (three blade) 18 HP TMO 3400005A
MTD makes these mowers.You should be able to use those part numbers to purchase replacements.You can find online at the mtd web site,or Lowe`s and wal mart sell those,or at least some of those parts.
May 12, 2011 | Computers & Internet
Left side blade cuts about an inch lower than right side , the left 21" when cutting is about an inch lower than the right 21", looks terrible, checked tire pressure and that was not the problem
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
Jun 14, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I need to replace the two 21-inch blades on my Craftsman rideable lawn mower.
I just watched the service technician change mine. He pulled the rear differential release out, then after removing the hood, he put a hoist on the front and stood it upright on it's rear wheels, and easily replaced both blades with a socket wrench. That beats all the work of removing the deck and turning it upside down.
Apr 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
What size and how many blades do I need for my husqvarna 21 hp riding mower with a 46 inch deck?
Well I guess laying down next to it and taking a look under the mower deck is beyond the question. One could ask about how many teeth the horse has or just look in its mouth. However, I am going to guess 3 blades as 2 blade units usually are 42" cut maximum. Mine is 48" and has 3 blades.
Mar 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Have to overlap about half my cutting deck to get clean cut.
A: Is the blade on right?
B: Is the belt on the pulley?
C: Is the blade tight on the spindle?
D: Does the spindle turn freely with the belt off?
I can't think of any other possibilities
Jul 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Apr 16, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
