Question about Hitachi 50GX30B 50". Rear Projection Television
My hitachi ultravision have double vision and corlor on top
  • Hitachi Master
  • 3,459 Answers
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
6my hitachi ultravision have double vision and - 0dcec37.jpg class=
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convermy hitachi ultravision have double vision and - 0667c5f.png are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 20, 2009
  • 25 Answers
The convergence on you television has come unaligned, you can have it realigned by a television repair professional. If a problem still exists the ic's on the convergence board may be bad in which case they will need to be replaced.
Posted on May 18, 2009
How can i fix my hitachi ultravision it has green and double vision on top of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Hdtv that has double vision
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
My hitachi ultra vision television is giving a double picture
This is a common problem with rear projection TVs. It will require pulling the convergence board out of your set and replacing two large ICs and several 1 watt resistors. It can be fixed no other way.
May 17, 2009 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Double vision two picture
conversion chip is blown do a google search on "replace conversion chip"
May 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Double vision with a lot of yellow color
This looks like bad convergance. If only one color is affected it may be one of the convergance IC's. It is best to replace both IC's though. If you change the IC's then check the resistors next to the IC's. Use the exact part numbers. STK392-110 IC's can be upgraded to a STK392-180 for better heat strength. (That is why they blow, too much heat generated. Use a liberal amount of Silicone Heat sink compound.) A shorted IC will usually blow a resistor. If a bad resistor that isn't changed it will look like the new chip is bad. Make sure that you use the same wattage and the exact value (Ohms). Your convergance will not be right with an off value resistor. This info works for about any other brand Projo TV. Cheers, Lee http://www.crazycomputers.com
Jul 21, 2007 | Hitachi UltraVision 55HDS52 Television
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
May 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50GX30B 50". Rear Projection Television Logo
1,231 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
