Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Apex model GB4308 Vertical Deflection failure
Hello All,
First this unit came into the shop with failed vertical deflection.
R370 and R371 was bad as well as TDA 8351. there was a post to replace c-863.
That is my problem I can not find C-863.
Does anyone know the location on theborad for this Cap? I have searched the C-800 area and others on the board. I am obviously overlooking it.
rgmiller2000
Sears used to sell these TVs, therefore they are likely to have parts, check with them.
Posted on Dec 14, 2007
Vertical line
Most probably the vertical deflection amplifier is failing. The most common part that fails is the vertical output transistor.
The set is too old to find documentation on part numbers and descriptions. Probably the part is no longer available and you will need the assistance of someone who can help you find an equivalent transistor that will do the job.
Of course, without testing we cannot be certain the failure is the output transistor. It could be from something else such as the voltage regulator that feeds the dc line to the vertical section. Could be the vertical synchronous level that goes too low to trigger the vertical sweep generator.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals
Good luck.
Jun 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Error code 2-3 it turns on and inmediately goes down
As far as I can recall, this set uses a standard vertical IC. Check that first. It should be an LA7837 or somethint similar. Also, check the capacitors in the same circuit as well as the supply voltages to the chip. If that fails to resolve the problem, please update this and we'll move on to other areas.
Dan
Apr 09, 2008 | Mitsubishi VS-50609 50" Rear Projection...
When I power on my Mitsubishi CS-35313 tv, I only get a thin horizontal line across the center of the picture tube. What could be the problem?
There is a failure in the vertical deflection circuit. Typically there is a vertical output i.c. that provides the deflection vertically. The i.c. itself is a fairly common component to fail. There are some lower power circuits that feed this output device that also could be the problem. When the electron beam in the tube is not deflected vertically it "writes" only horizontally across the center of the screen thus resulting in a single trace. Be careful not to leave this at high brightness for any extended time as it can "burn in" that area of the screen. Unless you are a "techi" this is a job for a qualified technician. Troubleshooting would be in the vertical deflection section of the set. Most of the parts are not expensive in themselves, except for the deflection yoke which sits around the neck of the tube. The cost to repair would typically be the shop labor.
Nov 25, 2009 | Televison & Video
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 08, 2009 | Orion1934 19" TV
I have a apex GB5108 tv, the picture has become a red yellow and blue horizontal line in the middle of the tv. is it fixable
Thats vertical deflection failure . Check the solder on the vertical output IC and the Yoke plugs. If that doesnt help you may need a new Vertical IC
Jul 01, 2008 | Apex Digital Televison & Video
HYUNDAI COLOUR TV HCT3740 (37CM)
No vertical is always an affordable fix.
- failed (dried out) electrolytic caps in the vertical circuit
- failed vertical IC
- failed power to the vertical circuit.
Hope Ya Fix It
Feb 07, 2008 | Televison & Video
Apex model#GB4308
If you mean a horizontal line going left to right across the center of the screen and it's intermittent then a tech should be able to fix that one on a service call fairly easy... The vertical IC in that unit, IC N301, is a TDA8351 and it most likely has some poor solder connections due to heat stress - we call ring cracked - thus the problem sometimes corrects itself temporarily. While he's coming out anyway ask him ahead of time to bring the following: Two resistors 1.0 ohm 2 watt and a cap 3300 microferet 25 volts and his DMM & ESR meter. Ask him to ESR test C863 this is a high failure cap and test R370 & R371 in the supply for change in value. Shouldn't be too much to repair - and simply ask ahead of time what they charge for a service call, and if they think they can correct such a problem (ring cracks on the solder connections of your vertical IC) on-site. If you're not too sure where to begin your research for a qualified shop try NESDA at: http://www.nesda.com/locator/state_search.php Good Luck Bill
Jun 13, 2007 | Apex Digital GB4308 43" Rear Projection...
Three colored lines across the middle...
Sounds like the vertical control IC has gone out. Replace IC N301 (TDA8351) and check or replace R370 (1ohm), R371(33ohm), and R380(1ohm). This shouldn't affect the sound but once you get video you might figure out what is wrong with the sound (control setting). The TDA8351 crosses to NTE7156 and shouldn't run you more than $10.
May 28, 2007 | Apex Digital GB5108 51" Rear Projection...
20 inch T.V.
You have a bad vertical output IC, or the sweep power supply that drives the IC is bad. Your going to need the service schematic diagram and the know how to fix solid state electronics.
Sep 01, 2006 | Durabrand DWT1905 TV
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
104 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
