Question about Farenheit TID-840 6.5 in. Portable Television
Tv not working
I own a 1989 ford custom van with a portable tv and which was operable. After not using the vehicle for a while i have since put it back on ht road. everthing works fine now except i cannot get the tv and cb radio to work. I have a feeling it might be the fuse. The DC plug is not directly plugged into the cigarette plug. how can i determine where the dc plug leads to so i can check the fuse. Or perhaps any other suggestions you might have to get the power i need to get the tv working?
    Problem Solver:
  • 9 Answers
If you place it on the windowsill so that it's just hanging and it falls off at the slightest touch. that'll fix it.
Posted on May 18, 2009
1989 Ford Econoline 150 Van will not start
Most all vehicles have main power cable to starter solenoid which is mounted on the starter where the power cable to the switch connects OR there is a separate heavy gauge red wire connected to the positive post of the battery that leads to the ignition switch. Also check your ground cable by connecting battery jumper cable to negative post on battery and other end to metal frame of van.
May 22, 2017 | Ford Econoline Cars & Trucks
1989 chevy van
probably the heater core hose under the hood going to probably a broken heater core ..I bet as a mechanic and a car salesman I am 100 % correct..LOL..You will see how correct I may have been ,,Hang in there ,,it happens
Oct 26, 2013 | Cars & Trucks
We have a 1989 ford 150 van 351 and it idle very
idle air control valve needs replaced loaded up with carbon
Apr 23, 2010 | 1988 Ford Econoline
Heater motor not working, checked fuses none,ford van
Probably the resistor plug located under the dash.
Dec 29, 2009 | 1989 Ford Econoline
Need users manual for ''durabrand'' television model du-1301. where can i download it?
Users manuals for this exact product are unavilablefor download at this movemnet. However, I did a custom search and found that the following links relate to your TV:
Durabrand TV (common models)
Funai Customer Support
(company that makes Durabrad TVs)
Durabrand13 INCH COLOR TELEVISION
(check this first)
Try out the above links and I hope you will find instructions to fully operate your TV.
Dec 11, 2009 | Televison & Video
Fuel System on E-150 Ford Van
yes each tank has its own pump in the tank
Aug 09, 2009 | 1989 Ford Econoline
1989 diesel 4x4 van will go into gear but will not move anywhere. replaced a seal due to a leak an now we have this problem. The van worked except for the leak prior to the replacement of the seal.
was the center shaft in the transmission installed? were the torque converter bolts put in?For a problem thats so sudden thats all i can think of at this point
May 03, 2009 | 1989 Ford Econoline
95 ford windstar 3.8 v6 transmission, no 3rd gear
First thing is to check the fluid level in the transmission, most vehicles have to be running at engine operating temp either in P or N, check your owners manual. Assuming your fluid is where it should be, that vehicle you have sorry to tell you are notorious for transmission failures, by what you described looks like your going to have to replace the trany or rebuild it, either way its not a cheap fix. My advise if the van is in really good condition put a used trany in it and trade it in for something else. You can look anywhere online about customer/ owner feed backs on 88-98 windstar vans and how bad the transmissions are on those Ford didn't get smart till 99 or 00 when they redisgned the drive train. If you keep driving it the way it is the trany will completely fail leaving you on the side of the road somewhere.
Mar 20, 2009 | 1995 Ford Windstar
1990 ford f150 cross over valve location
Please Help ME by Remembering to RATE ME Thank you Vrey Much !!!
This vehicle does not use an external fuel tank switching valve. A supply check valve in the fuel pump assembly opens when the outlet pressure from the energized fuel pump exceeds the opposing check valve spring force.
R E C A L L 1991
THE DUAL FUEL TANK SELECTOR VALVE MAY MALFUNCTION AND CAUSE AN OVERFILL CONDITION IN ONE OF THE FUEL TANKS, RESULTING IN AN OVERFLOW OF FUEL PAST THE FILLER CAP.
THE OVERFLOW OF FUEL PAST THE FILLER CAP CAUSES A FUEL LEAKAGE, WHICH CAN RESULT IN A FIRE WHEN EXPOSED TO A SOURCE OF IGNITION.
REPLACE THE DUAL FUEL TANK SELECTOR VALVE.
SYSTEM: FUEL TANK, AUXILIARY.
VANS AND LIGHT TRUCKS WITH DUAL FUEL TANKS PRODUCED IN THE FOLLOWING PERIODS: F150, F250, AND F350 LIGHT TRUCKS BUILT BETWEEN FEBRUARY 28, 1989 AND JULY, 1989; ECONOLINE BUILT BETWEEN FEBRUARY 28, 1989 AND FEBRUARY 11, 1991.
NOTE: FORD HAS AGREED TO RECALL THESE VEHICLES BUT PARTS ARE NOT YET AVAILABLE.PARTS WILL BE AVAILABLE IN DECEMBER 1991. YOU WILL RECEIVE A LETTER FROM FORD ADVISING YOU WHEN TO SCHEDULE AN APPOINTMENT WITH YOUR DEALER TO HAVE THE RECALL WORK PERFORMED. IN THE MEAN TIME, YOU CAN TAKE THE FOLLOWING PRECAUTIONS:FILL EACH TANK TO ONLY 1/3 FULL. IF YOUR VEHICLE LEAKS FUEL OR IF YOU SMELL FUEL, STOP USING THE VEHICLE AND CALL FORD AT (313) 446-4654 AND ADVISE THEM OF YOUR PROBLEM. REFER TO FORD SAFETY RECALL NUMBER 91S39. AN OPERATOR WILL TAKE YOUR NAME AND TELEPHONE NUMBER. A FORD REPRESENTATIVE WILL CALL YOU BACK
Jan 21, 2009 | 1990 Ford F150
Farenheit TID-840 6.5 in. Portable Television Logo
67 people viewed this question
Top Farenheit Televison & Video Experts
Electro Med Services...
Are you a Farenheit Televison and Video Expert? Answer questions, earn points and help others
