Question about Joby Inc FL201AM Gorillatorch Flare Flashlight Tripod
Wont light have inserted batteries with proper orientation--have tried different set of batteries--nothing
Key fob wont work changed the battery
I'm not really sure if this will work, but try disconnecting the negative terminal on battery, insert key in ignition (don't turn on, just insert it) then reattach cable.
Apr 04, 2016 | 2006 Dodge Grand Caravan
My fujifilm xp60 will not turn on, the battery is okay. the battery is inserted properly.What other cause could there be ?
Make sure battery is actually charged and charger is not faulty. Try a different battery? Make sure contacts on battery and camera are clean. If the camera still will not start, it may need to be serviced.
Sep 14, 2014 | FUJIFILM Cameras
Duracell charger wont charge..
The blinking indicator is telling you that the batteries have been inserted incorrectly. Otherwise, the charger probably no longer works
Jan 20, 2013 | Duracell AAA NiMH Battery Charger with 4...
My finepix s3400 will not turn on. I've tried almost everything and I'm really annoyed. Is there something i can do to fix it?
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
Mar 08, 2012 | Fuji FinePix 3800 Digital Camera
Myn psp go wont turn on or charge
Make sure the battery is properly inserted. If it is not make sure that the cable is plugged in properly on the psp, to the converter and to the wall. If nothing works try changing the battery and using a new one.
May 27, 2011 | Sony PSPgo Black Console
When i plugg in my camera to the computer it wont chrge it wont even turn on if there is a soultion please contact me asap!!!
Hey Sophia,
Have you checked the battery, as the problem seems to be with battery
First of all checked if the battery is inserted properly
Take it off and re-insert it... make sure the +ve and -ve are set properly
If it still does not work...you got to replace the battery
Thanks
Oct 08, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Nokia 6061 battery dead and wont charge
phone drown in washing machine but lcd lights and say please insert sim nothing else happens or work. What to do?
Jan 02, 2009 | Nokia 6061 Cellular Phone
Canon 40d-used camera sunday-took cf card to store to make pics-
Try cleaning the contacts for the batteries with a pencil eraser. Make sure you hold the camera so the eraser debris falls OUT of the battery compartment as you clean. Also make sure the battery door latches properly, and that the batteries are correctly oriented.
Dec 12, 2008 | Canon EOS 40D Digital Camera
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
NO Power
Possible causes Solutions
/ Corrective Actions
The power does not
turn on.
The ViviCam 6300
suddenly powers down.
The image is not
captured when the
shutter button is
pressed.
The flash does not fire.
Continuous shooting
is not possible.
Cannot transfer files
over a USB connection.
* Load new or fully charged battery.
* Load the battery in the correct direction.
* Close the battery cover correctly.
* Properly connect the AC power
adapter.
* Set the option of Auto Shut Down to Off.
* Turn the power back on or charge the
battery.
* Rotate the mode dial to A , P , SCENE
, Tv , Av or M.
Transfer the desired files to your
computer and then delete unnecessary
files, or use a different memory card.
* Select a different flash mode.
* Select [Single] in the capture mode .
* Insert a new SD memory card.
* Check all connections.
* Install the USB driver on your computer.
* Turn on the ViviCam 6300.
* The battery has run out.
* The battery is not oriented correctly.
* The battery cover is not closed properly.
* The AC power adapter (optional)
is disconnected.
* The function of Auto Shut Down in
Jan 25, 2008 | Vivitar ViviCam 5386 Digital Camera
Joby Inc FL201AM Gorillatorch Flare Flashlight Tripod Logo
23 people viewed this question
Top Joby Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Joby Photography Expert? Answer questions, earn points and help others
