Question about Ducane 7200R (NG) Grill
I need a replacement part for the push button ignitor, but can not find one on-line. Model 7200RA.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
I'm looking for a pietzo type push button ignitor
It will work if it can be mounted correctly in the heater and the push button part is the same size as the one you want to replace. If I knew what brand you have and the correct model number I could probably tell you where to find the exact replacement.
Hope this helped and thanks for choosing FixYa.
Sep 16, 2011 | General Heating & Cooling
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Can't get the pilot light to start
Is this the newer style with closed combustion chamber. If so I would check to make sure that spark ignitor is working. If not it will need replaced. If ignitor is workingthen loosen compression nut on line to pilot and temporarily depress button on gas valve to make sure you have gas at that point.If you have gas there and tighten compression nut to pilot back up and it still won't light then you will need to remove screws that hold cover on burner compartment.Shut off valve to gas supply and remove gas line from gas valve remove pilot and thermocouple lines. Slide burner out ofcompartment and clean it .Remove nut from bottom of pilot assembly and clean out pilot orifice. Blow through pilot line to make sure it's all clear
Reassemble everthing using teflon tape or pipe joint compound as needed.Turn gas supply valve on and check for leaks.Set gas valve control to pilot and depress pilot button and hold. While you are holding button done push spark ignitor every few seconds until it lights. thank you and good luck
Dec 22, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
When press bake button oven is not heating up
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jul 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My ge gas range wont work on BAKE but everything else works model JGS905SEK2SS
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one.
Feb 09, 2010 | GE Profile JGB900 Gas Kitchen Range
I bought a floor model gas grill and the igitor is not wired ( but all the wires are there). Anyone know how i attache the wires to the push button ignitor?
the push ignitor should have a spade attachment on it for the side burner wire and the main wire end should be round and will push into the end of the ignitor.
Nov 07, 2009 | Kenmore 632 sq. in. 16324
I have an older model Kenmore gas dryer. Model #87681110. It was not putting out heat so I replaced the ignitor. It worked for the first load of laundry but then began acting erratically. This evening...
hi bob,
try replacing the gas valve coils,
they are the hold and asist,
one allows voltage to the ignitor, one
allows voltage from ignitor to open the gas valve/ well actually resistance, but im sure you understand
they are pretty commanly the problem with your diagnosis
Oct 15, 2009 | Dryers
Ignition for the bake lower burner not lighting up
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Amperage should be 2.5-3A. If less than 2.5A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers : WB2X9154, 4342528, SGR403, 5304401265;
Those ignitors are interchangeable, if you can splice the wires. If not comfortable splicing wires - replace it with the first one in the list, should be direct replacement.
Sep 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
PUSH BUTTON IGNITOR DOES NOT LIGHT THE BURNERS
Clean any grease or residue that might be on the ignitor preventing it from sparking.  If it is clean and it does not spark when pressed, replace it.
May 20, 2009 | Grilling
Gas stove want heat
Nov 01, 2007 | Tappan TGF320 Gas Kitchen Range
Ducane 7200R (NG) Grill Logo
73 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
