Question about Epson Workforce 610 All-In-One InkJet Printer
Samsung clp 610 loud noise
Loud clicking noise from bottom of printer
Dear Expert how to reset chip ML-2850 Series printer, please help me
If firmware update is unsuccessful, you can throw printer.
I recommend you build yourself a very simple "reset device" (resetter) for many models including this one. Address is,
http://www.tradebit.com/filedetail.php/178510406-at88sc0204-reset-software-full-package
List of chips that can be reset is,
Samsung ML-1630
Samsung ML-1631
Samsung ML-2850
Samsung ML-2851
Samsung ML-3050
Samsung ML-3051
Samsung ML-3470
Samsung ML-3471
Samsung ML-3472
Samsung ML-4050
Samsung ML-4550
Samsung ML-4551
Samsung SCX-4500
Samsung SCX-4501
Samsung SCX-4725
Samsung SCX-5330
Samsung SCX-5525
Samsung SCX-5530
Samsung CF-560
Samsung CF-565
Samsung SF-560
Samsung SF-565
Samsung CLP-350 (Bl/M/C/Y)
Samsung CLP-351 (Bl/M/C/Y)
Samsung CLP-610 (Bl/M/C/Y)
Samsung CLP-660 (Bl/M/C/Y)
Samsung CLX-6200 (Bl/M/C/Y)
Samsung CLX-6210 (Bl/M/C/Y)
Samsung CLX-6240 (Bl/M/C/Y)
...and many others.
Excuse my poor English.
Aug 20, 2010 | Samsung ML-2850 Series
Samsung CLP-310N when printing it is very noisy
most probably the printer fuser unit is giving you the noise...
Jun 21, 2010 | Samsung Office Equipment & Supplies
Clicking noise when printing
Had similar problem. Putting my hands on the front surface of the printer, the click seemed to be felt strongest in front of the pink ink cartridge. I took the cartridge out, looked at the back of it, where there's a little black wheel, and tried turning it. That wheel was stuck (whereas the other colors & the black would turn). Tried printing with the pink cartridge out and no more clicking noise. I guess I'll just replace my pink cartridge. Maybe see if there's a similar problem with one of your cartridges?
May 13, 2010 | Samsung CLP 300 Laser Printer
When I turn on my Samsung CLP-600N laser printer, I just get a clicking noise. When I turn it off, it continues to click for a minute or two and then stops. The lights do not go on.
it sounds like a faulty power supply, when you apply power it charges the capacitors in the psu but as it is faulty is unstable hence the clicking, it continues as the capacitor discharge until all power drains
Apr 20, 2010 | Samsung CLP-600N Laser Printer
I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Apr 15, 2010 | Samsung CLP-500N Laser Printer
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Samsung 3160fn all in one printer. making loud clicking noise when printing
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
May 05, 2008 | Samsung CLP 300 Laser Printer
Epson Workforce 610 All-In-One InkJet Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
