Question about Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E
Got wet dark bands on left side of screen - Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E
Fix wet tv
Replace all ur vertical section condenser .
Apr 15, 2014 | Televison & Video
Dark band lcd tv
Back-light fault. Contact any service technician. The panel might be taken out for repair. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Tv-Dark area with lines when turned on
BAND IS SONY, WHAT IS MODEL NUMBER?
Apr 09, 2012 | Sony Televison & Video
Hello, I have a 40" Samsung LCD flatscreen. My television has a 2.5" diameter black spot on the far left side about 4" from the bottom of the screen, Also we have a dark transparent band across the bottom...
Sorry Sir but your LCD TV got wet... it can be splash with too much water, an animal urinate on the panel, etc....
this kind of black spot is caused when the LCD Panel Terminals got wet, this terminals are located at the lower side of the LCD Panel.
Sep 15, 2010 | Televison & Video
Dark band on left hand side of incoming faxes
Your toner cartridge is leaking toner onto the transfer roller. There is no cure except for replacing the cartridge.
Dec 10, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Dark band 6 inches wide middle of the screen
YOU MAY HAVE A DEFECTIVE Y DRIVER BOARD OR A RIBBON CABLE THAT HAS COME DISCONNECTED. THIS NOT USUALLY THE PANEL SINCE THE PANEL DOES TURN ON. TAKE IT TO AN AUTHORIZED SERVICER.
Apr 10, 2009 | Televison & Video
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Scanner screen
open the top glass cover,after that u can see the lamp assy ,on the banx
ck side of that assy there are some mirrors,clean all that mirrors with a cotton bud ,fix it again n chech\
do revert
th
Jan 26, 2008 | Umax Astra 2000U Flatbed Scanner
Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E Logo
13 people viewed this question
Top Generic Televison & Video Experts
richie46
Rigger
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
