Question about Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack
Wouldn't run. Bought new batteries. Tried charging again. Won't run. No horn
Can't tell if the new batteries are good as charger doesn't show green. There is no power
4 Suggested Answers
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
  • 692 Answers
SOURCE: I just bought a new battery charger cable called
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Posted on Oct 03, 2010
tbreeze47
  • 3083 Answers
SOURCE: Traveler Elite Plus: Unit will
I've been a tech for years, and sometimes any assumption that something is "good" can be the one thing that trips you up for awhile. This is a really tough problem, since you've done about all you can to solve it. Here's what I suspect...either the batteries don't have the same current capacity as the old ones, or they could be underengineered, or even defective. I've bought car batteries, on two occasions, that were bad, even though they swore they were good.
You'll have to get someone to test them for their load capacity, that's the only thing I can figure at this point. Not sure who will have this capability- you might call around to some service shops and see if they can help, or know someone who can.
If all the connections are good, and the motor is new, there just leaves the harness itself and the batteries to suspect.
Ensure the batteries are good, and then you will have to check the cables for load capability and integrity.
Good luck, and hope this helps.
Posted on Nov 24, 2010
Jazzy select gt. batteries are good charger is new when charging the lights go from red to green and repeats, but if i hold the button one red one yellow ? i tested the batteries they are full but joy...
Still your batteries are bad. Had this problem before. If the batteries are more than 1 to 2 years old they need to be replaced. The charger only tells you it can't charge anymore, because the battery is sulfated. The meter on the chair is telling you the batteries are not strong enough to run the chair.
Jul 18, 2017 | Select Health & Beauty
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack Logo
47 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
