Question about Canon NP 6551 Black and White Copier
Canon Copier 6025
System is telling me waster toner is full on my Canon 6025 copier. I ordered a manual but it does not mention waste toner. I do not see anything that resembles a waste toner collector. Where is it and how do I empty it?
  • Canon Expert
  • 1,326 Answers
The Waste Toner is located in the the drum unit it self. You need to remove the drum unit & on the top of the drum unit is a white or clear rectaular cap. You need to open it carefully and vac out the toner in side the unit. FYI if you are empting the waste toner the drum is just about worn out... Good Luck
Posted on May 18, 2009
Show me a picture of the waster toner on canon ir3035
It's in the front of the machine,abowe the paper casette.Part number for the waste toner box is FM2- 0303-000
Oct 08, 2014 | Canon iR3035 Copier
Erroro19
E019 0000 Waste toner full detection The waste toner full state was detected.Replace the drum unit.
0001Waster toner full detection sensor is faulty. . The waste toner full state was detected continuously for five or more seconds while the main motor was turning.
- Check the connector of the waster toner full sensor. - Replace the waste toner full sensor. - Replace the DC controller PCB.
Mar 10, 2011 | Canon iR 2016i Black and White Copier
Error code E019
E019
0001 Waste toner full detection
0002 Waster toner full detection sensor failure
you will have to replace the drum unit because it is full of waste toner.
Nov 14, 2010 | Canon iR 2016i Black and White Copier
I need to reset the waste toner until I receive a replacement for my ImageRunner C5051, is that possible?
This is incorrect. You can manually empty the waste. Make sure you remove the small clear plastic part that is on the side and empty it as well (this is what the sensor looks at to tell the macine it is full)
Sep 23, 2010 | Canon imageRUNNER 5570 Copier
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Need to locate the waste toner container on a Canon ir 6800
The waste toner bottle should be on the right side of the copier toward the rear of the copier. It is behind a pannel that is held in with 2 screws. Take the screw out & open the pannel & the bottel should be inside that opening it is a milky white container. Pull it out, it is rather large. When you dump out the toner make sure you have a plastic bag with No holes in it, it can be very messy if you are not carefull......Good Luck
May 20, 2009 | Canon IMAGERUNNER 6570 Copier
I have changed toner for copier NP-3050. Waste toner didn't remove. Is it necessary to remove the waste toner from the box ?
yes it's necessary to remove waste toner, because n long time the waste toner jamed the clining (I think in the 3050 the waster toner drop by a pipe inside the drum)
Mar 04, 2009 | Canon NP 6050 Copier
Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Jan 02, 2009 | Canon imageRUNNER 5020i Copier
Canon NP 6551 Black and White Copier Logo
321 people viewed this question
old marine
old marine
