Question about 12Volt Monster Trax Convertible Car 12-Volt Battery-Powered Ride-On, White
The car will not shift into reverse
Gear shift stick will move forward and click for forward shift no sound for shift stick for reverse and still moves forward
Izuzu rodeo drives forward on reverse gear
redux. (A/T trans answer not STICK SHIFTED manuals)
no years stated
no transmission stated, auto or stick.
stuck in Reverse.
linkage checks are first.
the trans has lever on the side
called the Manual valve.
it that lever does not go to DRIVE,
then there will be no drive.
there is a cable from the Shift selector to that
transmission side lever.
inspect these parts for proper movement
no damage, not slipping cable, etc.
only you can do that.
or your mechanic.
Dec 13, 2016 | Isuzu Rodeo Cars & Trucks
How do i trouble shoot automatic transmission that shifts from park to reverse with the gear shift but the car will not move?
Sounds like the shift cable is off the transmission under the hood. Raise the hood and check to see if the cable is moving the linkage going into the transmission when the shift lever is moved in the car. Be sure to have park brake on.
Sep 26, 2014 | 2001 Daewoo Leganza
Why is car abruptly jolting to a stop in reverse and not moving?
Sounds like the transmission is shifting into both reverse and a forward gear at the same time. Time for a tranny overhaul. But first check the transmission fluid level.
Jun 08, 2014 | 2004 Mazda 6
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
Nov 29, 2013 | Audi Cars & Trucks
I have a 2001 suburban that periodically locks up and wont move,but will if you shift gears from forward to reverse.any input
Is it a 4x4? Sounds like the transmission (or transfer case) is binding internally, or you brakes are locking up and shifting from forward to reverse frees them up.
Apr 02, 2013 | Cars & Trucks
1990 jetta wolfsburg
The shift linkage may need rebuilding. Inspect it. Jetta 3 2 0L 8V 9
Jun 04, 2017 | 1990 Volkswagen Jetta
My stick shift wont go into any gears, it only moves forward and backwards. this happened when the stick was being moved into reverse. what happened to my stick shift?
it sounds like the shift linkage came off the shifter, pull the shifter boot up and you should be able to get to the linkage
Mar 05, 2011 | 1993 Saturn SL1
I have a ford ka, and when trying to put it into reverse it made a weird clunking noise. And then wouldn't come out of reverse. I had to really push at the gear stick to get it out. I can't select any...
If the Gear is truck into unless the clutch disengages it wont shift. So start the car move slightly- if no space is a avialable jack up and let the drive wheel move- now shift the gear after depressing clutch. It must shift over now. If not repeat while the drive moves. You can now shift the car to forward gear .
Sep 14, 2010 | 1999 Mercury Sable
2001 Hyundai - reverse gear is inoperative. The
If I understand you correctly, you have ALL forward gears working, but reverse doesn't?... then the problem is in the transmission itself or the linkage on the trans linkage into reverse.
Oct 18, 2009 | Hyundai Accent Cars & Trucks
I can't get the gear shift to stay in place, it pops out
sounds like your clutch is bad... usually refered to as slipping clutch, meaning that when you put the stick in gear and take your foot off the clutch it slips outta gear
Jul 01, 2009 | LG enV VX9900 Cellular Phone
12Volt Monster Trax Convertible Car 12-Volt Battery-Powered Ride-On, White Logo
Top 12Volt Toys Experts
Andrew Taylor
Andrew Taylor
Are you a 12Volt Toy Expert? Answer questions, earn points and help others
