Question about Autodry Carwash System with Starter
Defy autodry is scraping and giving off iron filings
IT IS A DEFY AUTODRY TUMBLE DRYER. wHEN IN MOTION, THE DRUM IS SCRAPING, CAUSING A NOISE AND IRON FILINGS.
I have a defy autodry tumble dryer - about 5 years old. In good working order, but a few days ago when I pushed the on/off switch in to put the tumble dryer on, it went all the way in. It still works...
I have not personally seen one but in most cases with washers and dryers, access at the rear, removing a few screws might loosen the top from the back panel and that might allow the top to be pry open. The top is usually held in place with clips rather than screws...same as door panel in cars are held flush against the body of the car with clips. I would try removing the top by way of the back. Just a guess.
Feb 08, 2015 | Dryers
Defy autodry trouble shooting
Check the door latch. If that is faulty, the machine just remains in limbo until replaced. If you close the door and try and select a program and it wont proceed, normally means door latch is faulty.
Jul 03, 2014 | Washing Machines
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
Defy autodry, comes on timer works but will not tumble
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Dryers
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
A TUBE OF CONTACT CEMENT WORKS WONDERS ON THE SEALING RUBBER - JUST FOLLOW THE INSTRUCTIONS ON THE TUBE . IF ITS GOOD ENOUGH FOR DOOR SEALS IN THE AUTOMOTIVE INDUSTRY ITS GOOD ENOUGH TO HOLD YOUR DOOR SEAL IN PLACE - GOOD LUCK.
Jul 26, 2011 | Dryers
Where can i find a maneul on a defy 721
Check in this two links:
- Defy AutoDry
- Defy AutoMaid
Both in PDF format.
Apr 25, 2011 | Ovens
DEFY AUTODRY WIRING DIAGRAM
disconnect dry and in the back of dryer in top left hand corner is your diagram, looking from back of dryer, just remove the 6 screws from the top panel at the back of the dryer Good Luck Tim
Dec 26, 2010 | Dryers
Defy dryer, not heating
Check that you have 220v first. Your dryer will work on 110V but will not dry. You need to check all thermostats with a ohm meter (be sure to unplug dryer), they should be 2 ohms or less. Set ohm meter to 1x. If they are good go to heating element (your ohm meter should be on 1X as wel. You need to check to make sure you have continuity (however, this does not mean that it is not bad). You need to take it out and visually inspect it to make sure it has no breaks in the coil. If it does you can buy a rewire kit for runder 30 bucks for most models.
Jan 03, 2009 | Roper RES7646KQ Electric Dryer
Autodry Carwash System with Starter Logo
18 people viewed this question
Top Mr Clean Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Mr Clean Vehicle Part and Accessory Expert? Answer questions, earn points and help others
