Question about Maytag PAV2300 Top Load Washer
I have a Maytag Topload Washer Moderl PAVT2448WW
So I've had this machine for well over 5 years and it was working fine until two days ago (May 15, 2009). First it started to screech whenever it went into the rinse and spin cycle. Then it started to give off a smell (like burning). Now, it fills water and sorta washes clothes, but it can't go into the spin cycle. Could it be the a motor (if it even has one) or something? I'm not real good with mechanics, so I would not know. Plus, buying a new machine is not on my budget so yeah...
  • mrcookins May 18, 2009
    How much would that cost, you think?
    Scholar:
  • 85 Answers
Sounds like your pump has locked up(screeching sound) which caused the belt and motor pulley to get hot causing the smell. I see this all the time. You will need a new pump, belt and motor pulley to fix it.
Posted on May 18, 2009
  • shinn8
    shinn8 May 18, 2009
    Probably in the $200 range if you get a tech to do it. If you do it yourself parts will run about $100.
    Hope this helps
  • 975 Answers
It may need to replace the MAIN DRIVE BELT , before assuming it could be the motor, HOPE THIS HELPS , AJ
Ok, so I have a maytag atlantis serial number MAV7650AWW. Everything worked fine up until a couple days ago, the washer just stopped working it was full of water and seems as if it has no power at all
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jun 25, 2012 | Maytag Atlantis MAV7551 Top Load Washer
I have a Maytag Atlantis top load machine. It is 7 years old. I have very dark oil dripping from under the machine at the bottom edge of the front. I am assuming the gear box is gone but wanted to confirm...
Sorry to confirm your suspisions but its leaking oil from the transmission and its exxxpensive to replace the transmission. And sad but true the good ole days of dependabilty of the maytag is gone espically since 5 years ago Maytag was bought by Whirlpool. a Whirlpool is a good machine but nothing was good as the old Maytag's
Aug 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hello. I bought my Maytag LAT9304BGE (hard to read) 15 years ago and have been using it at least once a day since (usually more) with relatively no problems and great results. Early on I had a Maytag...
ok few things first one is that if you are on 15 years of use you are well well over life expectancy a modern washer will last round 5 years so in my honest opinion id get a new washer, also u said your husband put a pump from a different brand in there, yeah not a good idea the resistance ratings and wattage is normally different for every brand which will cause it to do pretty much exactly what u described, if u do wish to fix it tho u will have to get a new genuine maytag pump and if that doesnt work your probably looking at a control board, how much have you spent on repairs over its life? cos if youve spent more than 500 bucks on it youve already bought a new washer, youve gotta look at the long jeverty of it like u could fix the pump problem then the next week the motor could die and u jus wasted the money fixing it thats what youve gotta watch with old appliances so yeah my honest opinion get a new one
Mar 31, 2011 | Maytag Neptune MAH5500B Front Load Washer
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
I have topload maytag washer model lat9704aam that makes ahigh pitched squeal like metal on metal when spinning out mostly near the end never when starting
The problem will be the 2 inner bearings and the washer of the bearing to be replaced. kindly replace the bearing and washer then the machine will work fine
Dec 23, 2009 | Washing Machines
Maytag Preforma spins out of control
a couple of thoughts:
1. Take top off and check to make sure springs/absorbers are in place and not broken..
2. Try a load with no clothes and see if it happens.
Good luck.
Feb 27, 2017 | Maytag Washing Machines
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag PAV2300 Top Load Washer Logo
466 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
