Question about HP OfficeJet J4580 All-In-One Laser Printer
HP Photosmart 3110 All in One says ink cartdriges missing
I have this printer and the following message appear immediately after turning it one:
The following cartdrige(s) of ink are missing or is damaged. And ALL ( 6 of them) appear to be having the same problem. The thing is I can't even use any of the functions the photosmart has. What can I do for this? All cartdriges are in perfect state and non is missing.
    Problem Solver:
  • 10 Answers
I figured out the problem with my printer. If none of your ink cartridges are detected (missing) then follow the install steps below.
1. Turn on printer
2. After printer declares cartridges missing open the printer and remove the cartridges (advise putting a piece of paper under the cartridges to catch any ink that spills).
3. Turn off the printer (keep the top of the printer open)
4. Turn on the printer (still with the top of the printer open)
5. After the printer declares the cartridges missing again install the cartridges (while the printer is powered on). Close the top of the printer.
6. The printer should begin to cycle the ink into the printer and back out to the ink reservoirs.
7. After the ink cycle the printer should display genuine ink cartridges are installed
8. Make sure paper is in the tray so the printer can perform an alignment.
9. Everything should be ok after that.
Chad
Posted on Oct 09, 2014
    Scholar:
  • 155 Answers
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
Posted on May 18, 2009
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
HP Photosmart 3110 All-in-one not printing black ink but colour
have you found a solution to your black ink problem??? I am experiencing exactly what you describe, no error messages, I have reset the printer, alinged, cleaned etc but still not a single drop of black ink but all the colours are working fine. if you know what was wrong please let me know.
R
Jan 20, 2010 | HP Photosmart 3310 Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
Sep 21, 2009 | HP Photosmart 3310 Printer
Error message: ink device failure oxc18a0506
Perform the following on your printer http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jun 18, 2009 | HP PhotoSmart C5150 All-In-One InkJet...
HP OfficeJet J4580 All-In-One Laser Printer Logo
177 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
