Question about Dometic 541916 High Performance 15,000 BTU Air Conditioner Upper Unit
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
skrbin
  • 121 Answers
SOURCE: what startup surge Watts required for 5000btu Air Conditioner
1.5kW
Posted on Feb 17, 2009
motor1258
  • 6674 Answers
SOURCE: Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Posted on Sep 01, 2009
motor1258
  • 6674 Answers
SOURCE: My air conditioner keeps icing up.
Don't forget to drop ceiling assy enough to be sure that their are no restrictions or blockages on the forced side going into duct work etc, as well. Feel for cool air leaking across in to return air box as well.
Posted on Jul 26, 2010
  • 2418 Answers
SOURCE: I had a new dometic
First thing would be to check the drop cord you are using to run the trailer. Are you using a three wire drop cord? If you are running a normal 25 foot small diameter cord it can not carry the amps needed to run the A/C. Next You need a heavy duty cord like one would use for an air compressor. what all is turned on inside the trailer with the A/C?. I think that is why the installer suggested to use a 30 amp box closer to the trailer. If you want to run an amp check, if you have an clap on meter. Get an old drop cord and cut the Insu. so you can access the wire individuality and clamp around the wires. If no clamp on meter, do the math with your Ohm meter run a voltage check then read the ohms of the unit in the on position. If you have a good sized drop cord, and it is sized to carry the amps, we have to check the A/C compressor and fans amps usage, in which case you can access these components for amp use inside the A/C unit. . Hope this helps Fix Ya up.
Posted on Jun 18, 2011
Can the freon be recharged in this unit?
I believe that freon can be added to all air conditioners otherwise they would have a very short lifespan. The type of coolant may vary but they should all be rechargeable
Jun 23, 2015 | Danby 15,000 BTU Premier Window Air...
What code is E-7
loss of 120 volts to relay module
Jun 14, 2015 | Brisk Air Dometic A/C Roof Top Air...
Model 25373156301 air conditioner: What are the dimensions? How many BTU? Last year they were manufactured?
Found very little on that model: Kenmore 25373156301
24 in. Wide, 18 in. Height, 24 in. Depth and approx. 112 lbs.
15,000 BTU, Parts are still available.
Unknown date(s) of manufacture but Sears (Kenmore) does have similar (exact matches) models still in production.
Sep 13, 2014 | Heating & Cooling
Can you recharge. a dometic a/c rooftop unit serial number 991762724
No service ports on the unit. It needs to have a service port soldered to it and the system breached before you can check / charge.
Aug 29, 2014 | Brisk Air Dometic A/C Roof Top Air...
We just bought a new 29" 5th wheel camper, that has one 15,000 BTU roof unit. Should this one unit cool the rv?
Yes if its working properly. A 20 degree temp. differential between its supply air and return air its good.
Jul 02, 2011 | Dometic Rooftop RV Air Conditioner
Need to know BTU of Model ACQ158XSO Serial QT0601317
That would be a 15,000 BTU air conditioner...
That is what the "15" stands for in the model number...
heatman101
Apr 12, 2011 | Whirlpool ACQ158XP Wall/Window Air...
Dometic 541916 High Performance 15,000 BTU Air Conditioner Upper Unit Logo
59 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
