Gestetner #3470 copier has stopped working and displays this notification Functional problem sc 320 ...asks me to reset and then asks for service...I turned off and on to reset..did not work I believe that someone set the copier to quit and display this error...can you help me reset Big thanks ...my 758 students will be forever grateful if you can help us Sherry K. Lamb Nashville Public High School sherry.lamb@mnps.org
  • lura Oct 18, 2007
    yes I reported the wrong number
    should be gestetner 1502
    thanks for the info ...but hope you are wrong...am afraid that will mean that we will no longer have a copier because we will not be able to pay that amount of money...
    sigh....
  • shaiju_PP350 Mar 06, 2009
    gestetner 1502 error message sc 542 functional problem. how solve the message
Sc 542 functional problem. how repair these problem
Posted on Mar 21, 2009
  • shaiju pp Mar 21, 2009
  • 77 Answers
The other gentleman is right. The when the motor in the laser unit runs either slow,fast or just quits it will put that code up.Some times a tech can go into the computer and reset it,but the majority of the time it is only a small fix for it will come back.Yes it is costly I have already done one to the tune of $660.00 just for the unit not including the install and readjustment.
Posted on Oct 18, 2007
  • Scott Yeoman Oct 19, 2007
    I am sorry to say but it is the same problem for that model also.The exact diagnosis for it is , 320:Laser polygon motor problem.
  • 30 Answers
The model number of your machine doesn't match up with anything I've seen. I'm thinking that it's a machine built by Ricoh and if so, that S/C 320 indicates that the polygon mirror motor has failed. If that is the case, it's going to be a costly repair as that part is burried way inside the machine and isn't easy to replace by the average layman. Sorry I couldn't be more help. I'm about 5,500 miles away.
Aloha,
Bill Monroe
  • Bill Monroe
    Bill Monroe Oct 18, 2007
    Hi-
    Well now we know what we're dealing with. The part number for the polygon mirror motor is G029 1961. You might be able to buy one on EBay and if you can find someone with a little mechanical aptitude you might be able to get it done for a little over $250.00. I was able to buy one for about $75.00 plus shipping on EBay. If there aren't a horrendous number of copies on the machine counter, it's probably worth fixing.
    Aloha,
    Bill Monroe
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
While trying to print, my Gestetner DSc435 is displaying a functional probelm sc560.
Some expert may give the exact answer but according to my knowledge SC 5XX error code series indicates a problem in fuser or paper feeding sections.
Aug 29, 2011 | Ricoh Aficio 450 Copier
My problem is my photocopy is not working it says functional problem within the copier turn operation switch off then on if the error appears again call services sc 560 i dont have manual what can i do
Hi the error code 560 is for the BCU which is a control board for the machine it is not getting a signal from this unit...try this ...press the yellow clear button then enter 107 then hold down the stop/cancel button till the screen changes select copier sp then 5.mode use the arrows to select 810 sc reset execute this and turn machine off .. wait a few then turn back on, if the error was a slight missread it should work away but if the error comes back you may have to remove the back panel and check the connections mayb replace the board.. good luck A.
Sep 16, 2010 | Gestetner DSc338 Color Copier
Code SC195 Functional Problems
Enter SP mode: Press Clear (yellow) button, 1 0 7 and press and hold the Stop (orange) button for 3 secs. Then switch off and on again.
SC 195: Serial number mismatch
Serial number stored in memory is not correct.
Enter SP mode and check the serial number of the machine with SP5-811-002.
If the stored serial number is incorrect, possible causes are;
  1. NVRAM defective
  2. BICU (Main board) replaced without original NVRAM
Good luck and please rate me, thanks.
Feb 02, 2009 | Gestetner Copier
Sc546 on a gestetner dsm645
Dear sir; SC546 the problem onheating unit either thermister connection loose or fusing unit connection loose, if there have any problem let me know, if this information resolve your problem, please be generouse give me a good rating.thank you.
Dec 22, 2008 | Gestetner DSm645 Digital Imaging System
Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Oct 27, 2008 | Ricoh Aficio 250 Copier
Gestetner DSM616
Turn the machine on, and press clear modes, 1, 0 ,7, and press and hold the clear stop key. It will beep, and a menu will appear. Select copy SP (1), and then select data log (#7) scroll until you get to 7807 (sc/jam counter reset). select it, and press execute. exit all the way out, and recycle the power. If it comes to ready, it should be ok. If it happens again after that, there is a fuser problem of some sort.
Mar 05, 2008 | Gestetner DSm616 Printer
Machine display an error code sc 500
YOU MUST RESET machin by: press clear mode key(yellow)---enter 107 by keyboard----press clear/stop key (red) for4 seconds--- turn off machin and on
Dec 22, 2007 | Gestetner DSm615 Digital Imaging System
426 people viewed this question
k24674
jasbo
jasbo
