Question about Pentair MINIMAX NT TSI IGNITER
Heater min max nt powers up but will not call for heat
Heater will come on tells temp and power light is on and presure light and temp light but will not call for heat in the inside on the board the hi sensor light is on and the fuse light is on what might be wrong
    Problem Solver:
  • 10 Answers
I replace the ignition module . I did not recieve from your company i never got a reply to my problem. please notify me when my credit card payment has been reversed.
Posted on May 19, 2009
Why is there no display on my pentair mini max nt?
is ther power going to it if so check power supply or main power conversion board
Aug 22, 2014 | Pentair Minimax NT Heater
Master temp 250 will run for about 20 -30 min then go off. filter is clean, a pool man has put a jumper on I believe the lower one of limit switches right under the pressure. Also it would prior to this...
Any error codes? Also underneath the touchpad there is a button you can push that will allow you to set the max temp. after you turn power on press button. the green pool light will light up, at this point using the arrows adjust your max temp. press button again to change to spa, press again to operate.
Apr 27, 2014 | Pentair Mastertemp Heater
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Mar 29, 2010 | Pentair Minimax NT Heater
Thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
Jan 18, 2010 | Lux Elba OV 5085 LUX
E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Dec 03, 2009 | Pentair Minimax NT Heater
My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
Apr 16, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Pentair MINIMAX NT TSI IGNITER Logo
284 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
