Question about Roper RAX4233PQ Top Load Washer
WASHER FILLS AND AGITATES, BUT THEN STOPS, WILL NOT DRAIN OR SPIN
I LOADED THE WASHER AND WENT BACK TO DRY. THE WASHER WAS QUIET AND FULL OF WATER. IT FILLS BUT WHEN IT GETS TO THE DRAIN AND SPIN, STOPS. AT FIRST IT CLICKS FOR A COUPLE OF SECONDS AND STOPS. IS THIS THE TIMER THAT IS BROKE?
  • plrgt2 May 18, 2009
    THE WASHER IS ONLY MAYBE 3-4 YEARS OLD. THANKS PATSY
  • plrgt2 May 22, 2009
    I want to thank you. It is fixed. It was the lid switch. The whole thing was apart and when I lifted the top the thing fell apart. thanks again
    patsy
    Sergeant:
    Champion:
  • 214 Answers
It may be a bad lid switch. Cheak with your meter for continuity.And if you need more info let me know.Also how old is the washer for there are 2 differant styles of lid switch dipending on how old the washer is. hope i helped :)
Posted on May 18, 2009
  • tom wright
    tom wright May 18, 2009
    you can order the switch by using the model number .located under the door on the rear opening.That would be the first thing to cheak you may also have a bad timer but is not at all a commen problem.
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
My Estate TAWS800JQ washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin. If knob is manually moved from drain cycle to rinse unit will agitate but not drain or...
Possible that the drain pipe is in a height where the water is struggling to lift.
If not id check for a block. I normally find a sock stuck in the drain hose which causes a problem similar to yours
Sep 24, 2017 | Estate TAWS800JQ Top Load Washer
Not spinning or draining, only fills and agitates
the mixing valve in the rear needs to be repaced-it controls the water flow Also sounds like the clutch of the transmision maybe be a factor if the machine doesn't spin
Jul 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer agitates but doesn't spin or drain
something in your pump lean it back take hose off drain pump and clean it out
Dec 31, 2007 | Kenmore 49722
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Roper RAX4233PQ Top Load Washer Logo
210 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
