Question about Linksys WUSB300N Wireless Adapter
Will not automatically connect to network. Must reconnect manually each time.
This problem only happens when security is enabled, any kind of security, even WEP.  The router is a DLink 624i and both are set to WPA PSK. We have checked the password phrase a hundred times and that is not the issue, and we have checked all the available levels of security: WEP, WPA2 PSK and WPA PSK.  Firewalls are turned off on both computers and I've even tried this with Norton turned off.
Each time the satellite computer is turned on it must be manually connected to the network, and then shows throughput of about 54mbps, with signal strength of between 45 & 85%.   Once connected all works fine and to make it even more frustrating, every now and then there will be a connection and manual connection is not required.
I'm about to give up and buy an new router but I have a hunch that this is not a hardware issue. ANy thoughts would be appreciated.
Mark F.
  • Anonymous Mar 11, 2008
    I have the problem,
Hi Bear001,
I do not understand what you mean. The only entry that is asked for is the security code, the length of which varies depending on whether we try WPA or WEP. We are not working on a network, only using the router to broadcast a signal for the satellite laptop to use to access the web.
Thanks.
Mark F
Posted on Dec 25, 2007
    Sergeant:
  • 239 Answers
Did you put in The 26 digit code from your router? I know you need to have all computers on same workgroup , and the 26 digit code in all of them on your network, I think if you make sure, of those things mentioned above it may continue to work for you, I sure hope that gets you by your problem Thanks
Posted on Dec 24, 2007
Lenovo Z70-80 problem with wifi (don't show). Please do you know why? Thanks for any answer
see p18 of the user guide, downloadable from Lenovo website for how do this in win 8.1 (selt other o/s presumably)
it says
Connecting to wireless LAN - - -- - - - -- - - -- - - - -- - - -- - - - -- - - - -- - - -- - - - -- - - - -- - - -- -
Enabling wireless connection
To enable wireless functions, do one of the following:
• Press F7 ( ) to disable the Airplane mode if the mode is enabled.
• Open the charms, and select Settings ? to open the Network
configuration page. Toggle the Airplane mode switch to Off.
Connecting to a wireless LAN
After wireless has been enabled, the computer will automatically scan for
available wireless networks and display them in the wireless LAN network
list. To connect to a wireless network, click the network name in the list, and
then click Connect.
Note: Some networks require a network security key or passphrase for connection. To
connect to one of those networks, ask the network administrator or the Internet
Service Provider (ISP) for the security key or passphrase.
Jan 15, 2016 | Lenovo Computers & Internet
My pc always disconnected from the network
First,check the Connection settings:
1. Start Internet Explorer.
2. Click the Tools menu, and then click Internet Options.
3. Click the Connections tab.
4. Under Dial-up and VPN Settings, click the broadband connection, click Settings, and then click Automatically detect settings.
5. Click OK.
2nd:Disable the Security Software that would be blocking and enable Security Essentials
3rd:Download the latest driver for your Network adapter from the manufacturer's website which is compatible with the Operating system.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/pc-support/
Oct 01, 2012 | Computers & Internet
My router needs to be locked ,so no one can pirate my internet access,which hes been occurring lately
You didn't post the brand and model number of your router, but to access the setup on most routers:
type 192.168.1.1 (or if that doesn't work try 192.168.1.0)
user name is admin
password is admin
go to the security tab and st it up to use WPA2 and create a password.
Problem solved!
Jul 03, 2011 | Office Equipment & Supplies
80710723 error
A PS3 Error 80710723 signifies a network/router error. Try going to SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > (if wired, choose path 1. if wireless, choose path 2.)
1. WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
2. WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
Jun 15, 2011 | Sony PlayStation 3 40GB System
Error code 80710723
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
I set up my Belkin N Wireless Modem and it has been working fine. Except I did not install it with a "password" at the time of setup. How do I put in a password now. I cannot find a program in...
Hi psheayn,
Kindy copy this steps in notepad and also copy the screen shot before u start doing it.
You can put up a wireless password manually b logging in to the router interface but you should be very careful because if you change any thing else it might be a messup your whole router so kindly do the following steps alone.
Step 1: Open the internet explorer
Step 2: Clear the address bar and just type the number alone which is 192.168.2.1
Step 3: You will get router screen as below
Step 4: In the left corner of the page under "Wireless" Security and select security mode as "64 bit WEP "
Step 5: Type any 2 numbers per box as u like and apply changes. Also make sure that you are gonna copy the password. If you want to connect any other computer in future you will need to have that password to connect.
Step 6: Under security in left side select "WPS or Wifi Protected Setup" and select WPS as disabled and apply changes. Dont worry it not related to security its just an option that has to be disabled if you enable the 64 bit WEP password.
Step 7: Then Connect wireless computer to the wireless network name and will ask for the password this time since password has been enabled. And ur router is gonna be a protected one and no one can hack it.
Step 8: In case if ur not able to connect to the network remove the preferred network and connect to it.
To remove preferred network
XP OS
Start -->control pannel --> Network and Internet connection-->Network connection --> Right click on Wireless network connection icon --> Select 2nd tab Wireless network --> Remove preferred network one by one.
Windows Vista/ Windows 7
Start -->control pannel --> Network and Internet connection -->Network and sharing center --> In the left side select Manage Wireless network and remove preferred network one by one.
Check out the screen shot to enable security on the Router and to disabled WPS
Nov 06, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
A devise that will enable my notebook connect to wireless
Hi, You can add the networks through your system prefrences and set the wireless network to automatically connect to your mac book however the recomendation would be to always keep your settings to ask you before connectting to a wireless network, this will keep your notebook secure.
Jan 29, 2010 | Apple MacBook Mac Notebook
Wireless connection
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS > WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X hope this helps...rate me please, if it does...thanks
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Linksys WUSB300N Wireless Adapter Logo
381 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
