Question about RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater
Robeson heaters I have a Robeson model 03-2701 portable electric space heater ( fan forced heater / humidifier.) When I use the machine, I note that the portion of the power cord nearest to the electric wall circuit (where I plug it in), becomes very hot to the touch after limited usage. There is no fraying or tearing or cracks in the insulation material around the power cord. So, why is it heating up and what should I do ?
  • 659 Answers
SOURCE: ON-DEMAND WATER HEATER NOT WORKING
I am assuming that this is an electric unit? The heating elements could be bad. I would contact the manufacturer for a service manual for your unit. There you will find instructions on how you might be able to reset the unit if possible. One thing you can try is to shut all power down to the unit and then restart. Also check for any "reset" switches on it as well.
Posted on Apr 06, 2009
motor1258
  • 6674 Answers
SOURCE: Hot water heater is not working correctly on electric
Check that the by-pass valve(s) on or near back of water heater are in the proper position. If your stumped on how they should be for normal operation, remember this. Cold water has to flow into bottom of tank, so that valve needs to be open straight into that fitting. Then the hot comes out the top, so that valve has to be open as well. Any valves in between those lines need to be closed, otherwise it will mix cold and hot . If still not sure, get back to me, with location of any valves there, and I'll guide you through it.
Posted on Apr 25, 2010
  • 553 Answers
SOURCE: My water heater on electric is not heating to full
Most electric water heaters have 2 heating elements. The symptoms you're describing indicate that one of the elements has burned out and needs to be replaced. If you want to try to change it yourself you can contact me back through Fixya.com and I can try to explain how to do it.
Posted on Jun 05, 2010
  • 349 Answers
SOURCE: cracked water heater
Clean the crack up and expose clean metal by sanding it or a small grinder. Use JB weld it is a two part mixture that set's up hard as steel. Any hardware store should carry it.
I have fixed gas tanks,glasses and a few other thing's with it.
The main thing the surface has to be clean so the compound get's a grip to the metal. Since you already have a crack the compound will go into crack to get a inside bond.
You may use a small file or sand paper to open up the crack a little by adding a bevel to groove to expose shinning metal to get acurate bond.
Drain tank and let it dry out before attemping to fix.
They make all kind's of JB weld for different types of applications and Lowes or Home Depot will carry it.
Check out this link http://jbweld.net/index.php
Posted on Jun 10, 2010
bucky3d
SOURCE: have a 1999 Atwood GC10A-3E LP/Electric water
suggestion, ck your electric element to see if worn out.
you can ck with an ohms tester for current.
Posted on Oct 19, 2010
Testimonial: "Thanx as that was the problem!"
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Find a phone number for welbilt space heaters
Hi
you may be interested in the following link to Welbilt.
Trust this helps, regards Alan
Welbilt Corp History
Feb 11, 2015 | Comfort Zone NEW 09 Electric Portable...
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Robeson 03-2606-38 wick replacement instructions
Did you get instructions wtih the new wick?
Can you print them out, and share them with us?-- THen we could help you do the job. I did a search on the internet-- and they will not give us the instructions, unless wt buy the wick!-- Help us, and we can help you!
Mack B
Nov 02, 2013 | Heating & Cooling
Can i download a manual for this heater
http://www.allpartsinc.com/ProductDesc.aspx?code=PK115T&type=0&eq=&desc=PK115T---PORTABLE-FORCED-AIR-HEATER-&key=it
Nov 03, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Space heater is smoking smelling
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 10, 2010 | Reddy Heater R70 Portable Forced Air Space...
Need manual for serial # E0825340 model CZ 1500 wt
my comfort zone cz1500wt shuts off when turned on code A03 appears on the display
Oct 25, 2010 | Comfort Zone NEW 09 Electric Portable...
RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater Logo
93 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
