Question about Polaroid FLM-323B Television
HD/Cable Port does not work with HD Antenna
Plug HD antenna into HD Port and no stations can be scanned
SOURCE: CHANNEL DISPLAY
I had the same thing happening. 20.1 was 19.1 as well as 12.1, 12.2, and 12.3 were 38.1-38.3. In the last couple of weeks my tv has freaked out and died. I'm just passed one year so I think I'm screwed. I looked and it has corrosion on both boards. That might explain why the logic circuitry didn't work right. Maybe not. As a computer builder though I know corrosion is a bad thing.
Posted on Feb 07, 2008
  • 362 Answers
SOURCE: Cannot get digital OTA with antenna to work
Hi hindsite97, I will be happy to help.
  1. Press the menu button
  2. Use the up/down arrows to select Menu setup
  3. Press the right arrow button and then the up/down arrow button to select Auto Program
  4. Press the right arrow button to select Auto Search
  5. Press the right arrow button to begin Auto Search
This should FixYa as long as the Tv is operating correctly. Here is a link to the users manual in case you don't have it. http://www.polaroid.com/service/userguides/ce/lcd_tvs/fla3232b_fla3732b_ug.pdf
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
gjahn
  • 110 Answers
SOURCE: 323b - hdtv attached to hd antenna will not work anymore
If you have had a cable or dish connected previously, Check in your menu and make sure it is set up for antenna and not cable.
Posted on May 29, 2009
ripleymojica
  • 643 Answers
SOURCE: Polaroid TV with
tuner is bad. they dont make spare parts for that tv.
Posted on Jul 06, 2009
rulds2008
  • 3866 Answers
SOURCE: I have a Polaroid TLA-01911C. I switched from
Ether the antenna is not good enough for the digital signals that are now brodacasted or you got a bad digtal tuner in this unit. i would buy a antenna from radioshack special for this TV.
Posted on Jul 18, 2009
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
Nov 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    I don't now how i recive tv chanels in hd
    Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
    You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
    Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
    Mar 13, 2011 | LG 32LG30 32 in. LCD HDTV
    Cant get radio to play stops on station wont pick up antaina hooked up
    Check if the antenna male plug is completely plugged into the antenna port of the car stereo.If it is plugged well in the car radio but don't pick stations then your antenna cable is bad.You need to install a new set of antenna,available at any car audio supply.
    Jan 30, 2011 | Sony Car Audio & Video
    I have 42 inch toshiba, my husband cancelled our cable, is there a way to get the tv to work for just local channels??
    The instructions are in your TV manual, but because of the complexity of the TV and it's features, it may be difficult to find. I believe it is on P. 31 (at least of the manual I got online). You'll need to connect a TV antenna appropriate for your area. If broadcast sites are close (line of site) a simple bookshelf antenna will work. With the antenna connected, and the antenna input selected in setup, you allow the TV to scan for local channels in your area. I hope this helps you.
    Nov 21, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
    New dp 19648 sanyo hdtv no signal detected
    You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
    Dec 24, 2008 | Sanyo DS27820 27" TV
    DTV connection
    Have you tried http://www.antennaweb.org/aw/Address.aspx? This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
    Nov 10, 2008 | Televison & Video
    HD stations have no picture, sound only. Other inputs show picture.
    or antenna try ch 5 ch 12 re auto scan the chs in menu again readjust antenna
    Jan 29, 2008 | Toshiba 46H84 46" Rear Projection...
    Polaroid FLM-323B Television Logo
    11 people viewed this question
    Top Polaroid Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
