Question about Sony Televison & Video
Dvd player keeps saying No Disc, Insert disc - Sony Televison & Video
  • 36 Answers
When it loads the cd does it say loading before it sais no disc? if so, it may be the laser assembly, you can try cleaning it with a cotton bud dampened with alcohol like ethanol, if that doesnt work it is likely the laser assembly needs replacing, if it loads and unloads or sais no disc instantly, look at the sensor inside the drawer, (needs to be dismantled) this could be a microswitch. I would personally look at the laser and clean the lens and while you are in there, clean the wormwheel and guide that the assembly glides on, there could be dust on that or the grease may have dried and the laser cant reach the TOC, regrease them lightly, look for any belts and just replace them..Hope that helps Phil
Posted on May 18, 2009
stonephoenix
  • 563 Answers
SOURCE: No disc message on my coby 224 dvd player
Thanks for using FixYa.
If the unit is showing "no disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 07, 2009
SOURCE: DVD player says "no disc"
two DVD player with same problem. I think they are disposable. :(
Posted on Jan 20, 2008
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
  • 1810 Answers
SOURCE: when I insert disc screen comes up saying Disc Error, Eject disc
dirty dirty dirty
clean the dvd player
Posted on Jul 29, 2009
DVD player will play store bought dvd's but will say unknown disc when I insert one from Netflix.
Is it possible that this is a Blu-Ray disc from Netflix? If so, It may not be able to be read on a standard DVD player.
Another possible reason for this is that the disc is somehow damaged and thus unreadable.
I'm afraid without seeing the disc I am unable to help you further.
Either way, might be time to complain to Netflix:
Netflix Customer Service(800) 279-5688(888) 638-3549(800) 585-8131
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
GOT INSTRUCTION KEEP SAYING NO DISK
Hello
There are two possibilities for this fault. The first one is with the disc you insert in itself. If the disc is non-compactable to the player, no-disc display will appear after some time. Try with an other good known disc. No-disc display appear for every disc you insert in, the fault will be with its laser pickup assembley. If so it dhould be replaced. It is a skilled job. You must insist on same type and number of laser pickup unit. Chek whether the disc spins inside the player when it is inseted. If not, the sled motor is damaged. It should be replaced. To replace both laser pickup unit, and sled motor, you have to disassemble its mechanism.
Dec 17, 2011 | Durabrand DVD-1002 DVD Player
Everytime I put a disc in I get an error saying no disc
Does the disc you insert are original..If not is isn't posibbles for your dvd player to not recognize yor disc cause most of the branded dvd players like you have didn't read pirated disc..but if the disc you insert is original. Try to clean your dvd player using a dvd disc cleaner.
Jul 17, 2011 | Philips DVP5982
It keeps saying unknown disc,every time i put a disc in there every disc that i put in the player...it will not play it...it keeps saying Unknown-disc...including an audio-disc.
hi, try first to insert a clean up CD, and test your Cd or Dvd player with an original CD or Dvd, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
Sserpentio
Apr 12, 2009 | Insignia NS-VDVD1
Player keeps saying no disc why?
there r two reasons that the player says no disc on display. 1)the disc which you insert in your player is really not redable.check out that disc in any other player and confirm whether its working or showing the same fault in other player too. 2)the disc may be perfectly all right, but the lens in the player which reads the disc is either got dusty or the lens is turned faulty. for dussty lens you can clean it with tissue paper and check out .but for the faulty lens its necessary to replace the lens.thats a costly issue.
Feb 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
Cd burner--dvd player---vcr/dvd recorder/vcr
The disc isn't a compatible disc???????????
Nov 26, 2007 | Panasonic DMR-E55 DVD Recorder
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
Dec 25, 2006 | Samsung DVD-V8500 DVD Player/VCR
Televison & Video Logo
308 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
