Question about Pool & Spa
K star electric pool heater - Pool & Spa
Red indicator light will not turn on k star 10 electric pool heater
if power to unit then check transformer if power bad board if no then bad transformer
Jul 13, 2014 | Pool & Spa
How long does it take to heat a spa pool?
All depends on the amount of water in the spa or pool, and the size of the heater in BTU's. The time for "Heat Rise" will vary and the answer you are looking for can't be provided with amount of info you provided. But if a general rule of thumb - the closest answer: Spa with a gas heater, 1 degree about every 90 - 120 seconds. Electric heater (vary's by KW) on average: cold to hot = 8-13 hours. Swimming pool with gas heater (no suggestion for electric) about 1 degree temp rise every 90 minutes.
Dec 27, 2013 | Pool & Spa
Had same problem K-Star 10 both contactors, Check all your connections, I found 2 loose. If the contactor closes and can't get enough power the voltage drops, contactor starts to chatter. Loose connections also cause arcing and fires. The manual says do not store clorine in the same room.
I took the contactors out, to the bench, applied 208volts to the coil and beat on them till they stopped acting up. Put them back and they work. They are very ugly on the inside I will replace them as soon as I can find new ones on Monday..
Jul 17, 2013 | Pool & Spa
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
Is the Whirlpool Electric Water Heater Model # EE3J50RD045V energy star rated
You want to know if this heater has Energy Star label.
I don't know.
Call Whirlpool 1-877-817-6750
Energy Star is a label that means nothing to you.
Manufacturers use energy-star label to promote a product as a money-saver.
They can put an Energy Star label on a giant 10,000 square foot house, and you know that cannot be the truth that a large house saves energy vrs a smaller house.
Energy factor, (energy factor/ not energy star) on the other hand, is a comparison measure how efficient the water heater uses energy to heat a gallon of water, when water heater is absolutely new.
EE3J50RD045V has energy factor of .59, which is completely typical and ordinary for electric water heaters.
The EE3j 50 gallon is an ordinary electric water heater, with ordinary average .59 energy factor rating, so electricity to operate this water heater is same as any other typical 50 gallon electric water heater: it will cost $35-45 a month depending on incoming water temperature, hot water use, thermostatic setting, electricity pricing, and whether you operate heater at peak pricing, etc.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/How-much-does-it-cost-to-run-water-heater.html
The most important measure of water heater cost does not have anything to do with Energy-star or energy-factor.
The most important measure is total cost of owning and operating the water heater.
So if you spend $100 more to purchase electric water heater with slightly higher energy factor, then it will not pay you back. The difference will be $2 to $4 per year.
All costs are energy.
The total cost of operating water heater includes purchase price, installation cost, cost of repairs, cost of parts, whether you can fix it yourself, expected life of water heater, and replacement cost.
Every water heater has expected lifespan, and will not have resale value except current price of scrap.
Electric water heaters cost more to operate per month than same-size gas water heater.
Gas water heater might cost less over the life of water heater, but gas water heaters are increasingly expensive to repair, and increasingly more complicated, and cost more up-front to buy.
Electric water heaters cost less to buy, are easy to install yourself, are fully repairable by homeowner using generic off-the-shelf parts, and can be made to last many years by keeping tank clean and replacing anode rod every 2 years.
You can make ordinary 6-year electric water heater from box store last almost indefinitely.
Avoid electric water water heater that has electronic controls.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Sep 20, 2011 | Water Heaters
Pool heater recommendation
they make heat pump pool heaters. it works like an a/c but it heats. only uses electric. http://www.solardirect.com/pool_heaters/heat_pump_pool_heater/hpph.htm
also they have solar panels for pools. another good thing for a pool is a solar cover you just cover it when you are not using your pool.
May 29, 2010 | Jandy Lite2 LG400 Ceramic Compact Heater
Operating instructions for Aqualink RS8 pool/spa combo panel?
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till display says " clear memory "
Push star or enter
Push star or enter again to confirm.
You will get a message "erasing memory"
Now you can reprogram system
Nov 18, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
29 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
