Question about Roundup "" Weed & Grass Killer
My red apple iceplant is yellowish and not deep green despite what I think is adequate watering and the soil is light tan. (One is Monterey soil and the other is Topanga soil, and I'm not sure which is which). Another hillside has darker soil and has no watering, and the red apple leaves are dark green.
  • 3 Answers
The Red Delicious is an apple cultivar that was recognized in Wellsburg, Iowa in 1880. As the cultivar was optimized for color and durability for major supermarket chains, taste and texture were sacrificed, and consumers began to reject the Red Delicious
Posted on May 18, 2009
What can be done for beans or peas with stunted growth
Plants stunted; vines off-colour; roots rotten or absent. Root rot and crown rot. Improve soil drainage by adding aged compost to planting bed. Destroy infected plants. Rotate crops. Plant resistant varieties.
Leaves curl under and become deformed and yellowish. Aphids are tiny, oval, and yellowish to greenish pear-shaped insects that colonize on the undersides of leaves. They leave behind sticky honeydew. Spray away aphids with a blast of water. Use insecticidal soap.
Leaves turn pale green, yellow, or brown; dusty silver webs on undersides of leaves and between vines. Spider mites suck plant juices causing stippling. Spray with water or use insecticidal soap. Ladybugs and lacewings eat mites.
May 02, 2017 | Garden
I need speaker wire color codes from in dash the colors i have are blue and white gray black tan green and black brown and green white and pink blue and pinik
This should be what you need
Constant 12v+ Wire: Green/Violet
Switched 12v+ Wire: Yellow/Black
Ground Wire: Black/Light Green
Illumination Wire: Light Blue/Red
Antenna Trigger: Orange/Blue
Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Dec 26, 2010 | 1995 Ford Explorer
Rewiring 1968 cutlass I need color codes
The wire color code is as follows:
BLK= Black
BRN= Brown
RED= Red
ORG= Orange
YEL= Yellow
GRN= Green
BLU= Blue
GRY= Grey
WHT= White
PPL= Purple
PNK= Pink
TAN= Tan
LT BLU= Light Blue
DK BLU= Dark Blue
LT GRN= Light Green
DK GRN= Dark Green
Let me know if you require any further assistance.
Oct 20, 2010 | Oldsmobile Cutlass Cars & Trucks
I need a copy of the wiring diagram/color code for the colby stereo system in a 90-FORD AEROSTAR
90 Ford Aerostar Colby Stereo System
Wiring color code:
Speaker Power Ground
Left Front Orange/light green Light Blue/white
Right front White/light green Dark green/orange
Right Rear Tan/light green Brown/black
Left Rear Tan/white Tan/yellow
Other Wires:
Yellow/black = Hot - Key On
Light green/yellow = Hot - Direct to Battery
Light blue/Red = Radio lights
Black = Ground
Black/light green = Ground
This is what I found for you,hope it helps. Good luck.
Sep 26, 2010 | Car Audio & Video
Need factory wiring codes for a 1999 jeep grand cherokee
battery red/white
accessory white/red
ground black
LF - light green/green
LF + light green/red
RF- light blue/ black
RF+ light blue/red
RR- tan/dark green
RR+ white/violet
LR- white/dark green
LR+ dark green/white
Dimmer orange
This wiring is for the standard audio system
Sep 17, 2010 | Car Audio & Video
Auto wiring diagram
Battery PINK (+) RADIO HARNESS
Accesory BROWN/RED (+) RADIO HARNESS
Ground BLACK/DARK GREEN (-) RADIO HARNESS
Illumination ORANGE/DARK BLUE (+) RADIO HARNESS
LF Speaker (+) LIGHT GREEN/RED
LF Speaker (-) LIGHT GREEN/DARK GREEN
RF Speaker (+) LIGHT BLUE/VIOLET
RF Speaker (-) LIGHT BLUE/BLACK
LR Speaker (+) WHITE/RED
LR Speaker (-) WHITE/BLACK
RR Speaker (+) TAN/VIOLET
RR Speaker (-) TAN/BLACK
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2009 | 2008 Dodge Ram 2500
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
Aug 24, 2009 | Alpine Car Audio & Video
Internet cutting on and off
If you haven't done a firmware upgrade I think doing so will be of a benefit to your problem! Just remember to backup your router settings beforehand! Hope this helps!
--Joshua79
Apr 05, 2009 | Linksys Wireless-G WRT54GS Router...
Newly planted red apple iceplant but weeds are taking over
I have heard of two possible choices, the first is a product called "Killer" sold at Armstrongs Gargen centers that may kill the grass, but not the Ice Plants. Check out - http://www.garden-counselor-lawn-care.com/kill-crabgrass.html
and
http://en.allexperts.com/q/Lawns-725/Redapple-iceplant-weeds.htm
Good Luck, I Have not used it, but going to in the next couple of days, seems to be the best choice I can find so far.
Mar 21, 2009 | Roundup "" Weed & Grass Killer
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Roundup "" Weed & Grass Killer Logo
275 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
