Question about GE Kitchen Ranges
My oven does not shut off.
My GE Electric stove oven stay on when I turn it off. It is set to off but inside the oven is still warm 13 hours later. It is not too hot. Just stays real warm. What is the reason for this and how do I fix the problem.
Hot in Tennessee
  • 6,784 Answers
Hi there, this is a serious control fault that may be fixed by unplugging this unit for a five minute period. after this hard reset, plug the unit back into the wall outlet and power up. if the unit continues to stay on, you will need to replace the control(electric oven control)board.
Posted on May 18, 2009
  • BobFogarty Oct 16, 2011
    Just fixed my GE oven from being warm/hot all the time. The bottom element had a wire that was grounding itself against the stove. I moved it off of the side and now it works great!
  • Michael Masters
    Michael Masters Oct 17, 2011
    90% of the time its a stuck relay that is mounted on the control board, but a grounded element contact will also produce theses occurences as well. Nice job...
What's causing my oven to stay hot HOURS after I've turned it off?
If you have the older type stove with the oven knob that has the temperature setting around the outside of the knob, then that part could be bad. It is called a thermostat. That part usually comes with sensor attached. The sensor is the long skinny looking tube that goes through a hole and into the oven.
If you have the newer type electronic stove where you program in the temperature you want, the electronic circuit board could be bad. But the electronic stoves have a over temperature protection built into the circuit board, so that would have engaged, shutting down the stove.
Either way, it is a potential fire hazard and needs to be addressed.
Nov 07, 2014 | Hotpoint Ovens
Just started renting house that has the Maytag Performa Electric Range and I noticed last night that the "on indicator" light is on (and still on tis morning); however, none of the burners nor the sto
The pilot indicator is powered by a contact in the thermostat or control board. It is usually not powering the oven but it could be allowing 120 volts to the element this would make the oven very warm. If you unplug the stove for a while and then plug it back in and the oven gets warm again I would have it checked. It may be drawing power.
Sep 24, 2014 | Kitchen Ranges
Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Jun 21, 2009 | Ovens
Vintage General Electric Range
Lazidaisies,
you asked where can I find a service manual for a vintage stove? General Electric, 24"wide, push-button, electric; 1950s.
Placard on inside of oven door is "erased", except for embossed numbers: On the Left = 1 1245W2M2 10 7 On the Right = NM28552
You should go to GE and call them on the phone. They will have th resources to give you this Manuel!
bless you,
huuum
Please rate me before you sign off
Sep 12, 2008 | Kitchen Ranges
Frigidaire stove with oven
I have the same problem. Any resolutions for you?
May 08, 2008 | Frigidaire FEB30S5D Electric Single Oven
Ge jbp77 radiant range
my stove shut off. it want stay on
Ken
Dec 11, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
1,606 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
