Question about Car Audio & Video
Ice power ivm 7000 dvd player cannot connect to blackberry via bluetooth, blackberry asks for a password
SOURCE: Princess DVD player
Manual says use 136900 to change the numerical password.
Posted on Mar 12, 2008
Z1G ZA9
  • 122 Answers
SOURCE: how to connect via bluetooth my blackberry and my macbook?
Hi
to receive data files on a Blackberry you need to 1st make sure your device is set to visible in bluetooth settings. If the BB is receiving? In menu select media, once in media menu press BB button. A sub menu will pop up and you should see an option to receive by bluetooth? Select this and now the device should say 'waiting for connection'. Now send file from other device and it should receive. Hope that helps?
Posted on May 03, 2009
cj2176
  • 520 Answers
SOURCE: Trying to connect via bluetooth adapter bu10 and the installation asks for a security code
The initial security code should be 0000, this is assuming that you've not changed it.
For any future questions or issues I'm also including the support link for your printer.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=257&modelid=14723#SupportDetailAct
Posted on May 12, 2009
  • 42 Answers
SOURCE: blackberry cant receive pics from nokia via bluetooth
Email the picture.... and then open the email on your blackberry.... that should work if the nokia 6680 has Email capabilities...
Posted on Jun 03, 2009
al-sultan
  • 250 Answers
SOURCE: I can send files via my blackberry pearl 8110 bluetooth, but iam
1. Go to Media.
2. Hit the menu key (left of trackball) and select Explore.
3. Browse to the folder you want to store the file in.
5. Hit Menu key again and select "receive using bluetooth."
6. Send from the other phone.
You'll have to do this for each file individually.
Also make sure that you have paired with the device you are trying to receive from. In my limited experience i noticed that NOTHING transfers unless you are paired.
There is one more setting I would check, go to OPTIONS/SECURITY/GENERAL SETTINGS/make user the the
option for CONTENT PROTECTION is disabled.
Posted on Jul 18, 2009
How do I pair my WEP 200 samsung bluetooth to my phone blackberry phone
Your phone MUST have the bluetooth on and discoverable. When it is press and hold the power button on the WEP200 until the light turns on steady should be 5 to 10 seconds. With this done, use your blackberry to search for a new device, should be in the bluetooth menu. It should find the headset. Your phone will ask for a password enter "0000" (four zeros) then press pair or enter. It will take a few seconds to connect. Your phone will automatically connect to this headset when you power it on. Don't forget to turn the phone back to un-discoverable when done. I hope this helps.
Oct 14, 2009 | Samsung WEP200 Headset
Can send, but can NOT receive via bluetooth on BB 8110
I contacted the supplier and found out that the handset is faulty. As it was not a simple technical problem, they will exchange the handset- hopefully with a faultless one!
Thanks
Shast
Aug 28, 2009 | RIM Blackberry 8110 Cellular Phone
I have a Blackberry 8310. When I try to connect
go into bluetooth setup screen and hit options, make sure BB is set to discoverable. Then hit menu again and choose "add device".
Aug 21, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
Jensen VM9512 Address Book (Bluetooth)
There is a delay as it downloads and therefore you scroll and wait for the page to download. Occasionally I scroll back and forth to the first page until I get the next page.
Jun 17, 2008 | Jensen VM9510 Car DVD Player
Bluetooth Issues
I am thinking that it is prompting your for the "bluetooth" security code that allows the connection between the 2 devices (code is "0000")....
Make sure in OPTIONS / SECURITY / GENERAL SETTINGS, that you did not accidently enable a password.
Hope that helps! :)
Oct 03, 2007 | RIM BlackBerry 7290
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
