Question about Dell Latitude C840 Notebook
Screen takes several power up attempts to fire up
I have a Dell Latitude C840 that i have to repeatedly press the power button on off on off sometimes maybe 20 times for the screen to fire up. Everything else seems to be getting good power as the hd and cd drive both spool up as well as all the indicator lights coming on. My best guess would be something faulty in the lcd inverter board, maybe bad caps? I don't know. I'd like an experts advice before tearing into it. Thanks!
  • 3 more comments
  • av8tr_777 May 18, 2009
    To reply to benwabnick, yes thats exactly what it does.
    To reply to Geekman I will try reseating the cable and report back on that. as far as the other symptoms, The brightness color and picture are perfect and crystal clear once its on.
    Thanks for the speedy replies you guys are awesome!
    Ok I reseated the cable from the lcd to the video card which did appear to not be pushed in all the way but no joy on the problem. I have noticed however and I don't know if this helps, but the longer it stays off the harder it is to get the screen to fire up. i.e. If I just freshly shut the computer off the lcd will come right on if I turn it right back on. If I let it set for say 5 min it might take 3 tries. If I let it set over night it may take up to 20 or so tries.
    Ok I just tried hooking an external monitor as instructed by Geekman with some interesting results. When I turned it on with the external monitor hooked up while the LCD stayed blank as usual, the external monitor displayed lots of..I don't really know how to explain...but lots of all different colored pixels meshed with some lines flashing. Then after the on off on off routine a couple times I had the normal picture showing on both monitors.
    Thanks again!
    Ran a memtest86+ passed 100%. So i'm off to ebay to hunt video cards :)
    Thanks to all of you...I really appreciate it!
    Oh yeah I forgot to mention this earlier but I have an LG Flatron LCD that does the exact same dang thing..I'll have to go look for the section here to post that one.
    Thanks again!!! :-)
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Does the laptop always turn on but once every so many tries the screen will come on?
  • Dell Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 18, 2009
  • Chris Hingee
    Chris Hingee May 18, 2009
    You seem to have a flakey video card or video RAM, the proof is that you can sometimes see a normal picture on both monitors.
    The video card uses part of the memory of the RAM module/s.
    Try reseating the RAM modules and or test them in another laptop or test them at your friendly computer shop.
    There is not much you can do if the video card is flakey/faulty as it is part of the motherboard, and most likely it will fail sometime in the future.
What do I do when the used dell latitude c840 i received has just a white screen when I power it on?
might be a bad lcd or try to reseat the lcd cable on both ends on the motherboard and behind the lcd
May 14, 2014 | Dell Latitude C840 Notebook
CAN A DELL LATITUDE C840 BE BOOTED FROM ITS USB
power laptop on then pressing F12 and the Boot Device Menu appears
if usb is not an option on the list you cannot do it
Jan 27, 2014 | Dell Latitude C840 Notebook
How do i replace ide/eide cable on my dell latitude c840
Buy a replacement and fit it I guess. Why would you need to replace an item that doesn't fail?
As far as I am aware there is an adapter; http://www.ebay.co.uk/itm/HDD-Hard-Disk-Drive-Caddy-IDE-Adapter-Connector-DELL-LATITUDE-C800-C810-C840-/380698290269?pt=Laptop_Adapters_Chargers&hash=item58a362e85d and maybe a flexible cable; but that is for the screen.
Jan 21, 2014 | Dell Latitude C840 Notebook
How do I re format my dell 600 latitude to give to a teenager
Thats not an issue!
It can be done by pressing CTRL + F11 at the Dell Screen when the computer first turns on. Be sure to press and release the keys at the same time to access it. Sometimes pressing and releasing the keys several times in a row at the Dell screen can make it easier to access. Please be aware that this can take several attempts to successfully access this menu.
Now Choose the Appropriate Menu to Restore Your System to Factory Defaults.
It will Erase All the Data which is there on the Computer and the Computer would go to its new State.
Good Luck!!!!!
Dec 30, 2011 | Dell Latitude D600 Notebook
Need to reset cmos for booting to DVD drive dell latitude c840
Hi try pressing the ESC button during boot up, sometimes its the delete button, then select this drive by scrolling down, select CD drive for primary boot device, save changes and reboot. Hope this helps, come back to me if you need more help?
Jul 07, 2010 | Dell Latitude C840 Notebook
How to turn my wifi on on my dell latitude c840?
most dell laptops you hold the FN and F1 button down the outher way is go into Network Connections right click on the wireless and then enable hope this works.
Dec 29, 2009 | Dell Latitude C840 Notebook
Where is the FN button on a Dell C840?
The Fn key is to the right of the Ctrl key.
Jun 12, 2009 | Dell Latitude C840 Notebook
Dell Inspiron 8200 Won't Boot up. Not even to BIOS.
Latitudes sometimes have a problem with RAM. Try these things to get it to boot...
1. Remove the RAM modules, clean the contacts with a pencil eraser, reseat modules and test.
2. If two modules, remove one and test. Place same module in second slot and test.
db
Mar 24, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Latitude C840 Notebook Logo
223 people viewed this question
Alun Cox
