Question about Roland Music
Need to adjust touch sensitivity on a roland ep85 keyboard
I need to adjust the sensitivity on a roland ep85 keyboard. There is no user adjustment; however is there a 'special' way to do this? i.e. two keypresses? The ep95 has a two position hard wired switch for soft/hard, so I think that there may be some generic method?
4 Suggested Answers
  • 66 Answers
SOURCE: i need a free user manual for a roland u-20 rspcm
Found it! My 16 year old musicion picked up one of these and it is in desperate need of repair. I found the manual here:
ftp://ftp.roland.co.uk/productsupport/Manuals/U-20_OM.pdf
Posted on Aug 25, 2009
  • 5603 Answers
SOURCE: YPG535 keyboard is touch sensitive
Yep! Each key has two contacts, These are often conductive rubber pills that are pressed by the keys onto circuit traces completing the circuit. One of the contacts makes before the other so the procesor can measure the time between the closure of the two contacts. When one of the contacts doesn't make, the velocity is sensed as MAXIMUM so it HAMMERS !!!
Your problem is a contact isn't making... Your probllem to fix it is to ACCESS the contacts to clean them. Clean the contacts with ONLY 99% isoprophyl alcohol and Q tips.
Posted on Mar 01, 2011
SOURCE: I have a Roland Rhodes Model 660 keyboard/synth and cannot find a user's manual
http://media.rolandus.com/manuals/M-660_OM.pdf
Posted on Jul 20, 2011
Having a problem with the touch screen with my Roland E80 keyboard work station. Very slow or no change . Please help .
Open up the Roland E-80 and check if all connectors and flatcables are well seated.
Dec 21, 2016 | Roland Music
Some of my Roland keys are loader
This will not be user fixable. Check the Roland site for a service center near you.
Sep 17, 2015 | Roland Music
Are the currently manufactured Roland Home Piano series pedal assemblies compatible with the Roland HP237?
This wish an after market pedal, or the original 3's connector? If the keyboard is on when you plug and unplug that, it is likely due to a voltage reference getting confused. Usually when you get constant sustain then most likely a switch is stuck closed, or open, down there in the pedal. How these things work normally is that a pliable switch is opened, for sustain, or closed. It depends on the keyboard. Some keyboards have a setting inside them to accommodate both types of pedals, and some pedals have a switch to choose either. Your keyboard does not have a setting that I can tell, other than adjustments for a resonance option (nice feature). I am not sure the newer RPU-3 pedal is compatible, it seems to be for the newer models. If you are handy with a volt meter, then can check the cable's pins for a common, then a pin that changes with each pedal (use continuity mode, beeps when circuit is closed). Could be a piece of dust is in there, or hair or carpet stuff, and a good cleaning would fix that from blocking the normal function. Manual Link: http://media.rolandus.com/manuals/HP-237_OM.pdf
Aug 02, 2014 | Roland Hp337 Digital Piano
I have a TD9KX and the problem i get is right in the centre of snare the sound seems to overload or is too sensitive. I cant get rid of this even when adjusting sensivity.
If the drum set is older, the cone that is in the center that transfers the hit to the piezo is degraded. You can find replacements on Ebay. You have to remove 4 screws to get the bridge under the snare out and then peel off the old cone from the piezo disk CAREFULLY and then stick new one on. The point of these goes bad. You will then want to adjust the height of the cone with the adjuster screws so it is barely, barely touching the drum head.
May 15, 2011 | Roland Elektronische Musikinstrumente...
My KD-8 bass drum pad will now only trigger if it is hit really hard- I've tried altering the sensitivity at the brain to no avail any ideas please ? Thanks
SOME of these have a small potentiometer inside the pad part... The pot is VERY fragile and one needs a small jewler's screwdriver to adjust. You have to be careful as excess pressure on the screwdriver breaks the part off the circuit board inside. The access hole is only about 1/8 inch diameter.
Apr 12, 2011 | Roland Elektronische Musikinstrumente...
My roland td3 drums are playing the crash noise on every drum i am hitting even when crash is disconnected, why is this please?
Your Xtalk filter is set too low. Refer to the owners manual for how to adjust individual triggers' sensitivity to "cross-talk" (vibrations carried from other pads)
My bet is you unplugged the crash trigger, but not the cable from the actual module (the brain). If you have a cable connected to the brain but not to a trigger, than any little bump to the end of the cable that isn't connected can be picked up as though you hit the pad normally. (play with the end of the cable a little, you'll see what I mean. It's kind of neat.)
Jan 14, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
I my gr 20 is only picking up e a d g b and not the last string ,is there any way i can test it to find the fault please thnk you
If you want help from Roland you will have to register:http://www.rolandus.com/backstage/login.php That will get you access to full support and their email address. I think you are having problems with your GK-3 pickup. Make sure your string that you are having problems with is the optimal height etc. The adjustment for the GR-20 is in the manual at this link:http://www.roland.co.uk/assets/media/pdf/GR_20_Q_A.pdf Make sure your pickup is installed correctly and adjusted properly first. The manual is here:http://lib.roland.co.jp/support/en/manuals/res/1811530/GK-3_e11.pdf If you have everything adjusted and only one string is not working then I would guess you have a cable problem and the best thing is to contact Roland for advice. I didn't walk you through the adjustment because every installation for every guitar is different. Hope this helps.
Oct 24, 2010 | Roland Gr33 Guitar Synthesizer
I need a free user manual for a roland u-20 rspcm keyboard are there any ???
Jul 10, 2009 | Roland Music
www.rangeraudio.com has a good selection of manuals.
Apr 23, 2009 | Music
Roland GK-2A pickup. g string does not respond
I have the same problem. Only the 1st, 3rd and 5th strings respond. This is not a sensitivity adjustment. The unit does not see the strings. I called Roland and was able to purchase just the pickup itself rather that the entire GK-3. The pickup was about $35 but took 4 weeks to arrive. When it finally got here I was excited. It was not difficult to remove the old and replace it with the new. I plugged it in. NOTHING CHANGED! I believe and hope it ti the 13-pin cable. I have read where these cables are just poorly made and many users have spent a considerable sum on the cable, most recommending having one in reserve always as they are sure to go out.
Dec 31, 2008 | Music
Music Logo
19 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
