Question about Hansgrohe 06358620 Pressure Balance Valve w/ Scroll Handle Oil Rub Bronze
How to remove my hansgrohe mixer tap - Hansgrohe 06358620 Pressure Balance Valve w/ Scroll Handle Oil Rub Bronze
How do you remove the knob from a hansgrohe 17030 bathroom sink tap
Please post a picture of what you have .I searched but on images there are way too many to guess what it might look like
Feb 22, 2015 | Hansgrohe Plumbing
Hansgrohe Mondial 15005000 leaking
the mixer ball springs have become weak take them out and pull them out using two pairs of pilers then re-install them.
Dec 03, 2013 | Hansgrohe Plumbing
Hansgrohe ecostat not at full water flow
The most likely cause for a decrease in flow on the Ecostat mixer is debris in the filter screens. Try removing the thermostatic cartridge and cleaning the filter screens on the the cartridge. Doing so will most likely resolve the low flow issue. If you need instructions feel free to contact me at Hansgrohe Tech. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to provide instructions for the Ecostat mixer.
Feb 04, 2013 | Plumbing
Leaking tap
This is most likely a cartridge that has worn out and needs to be replaced. Most of the kitchen faucets use cartridge number 92730000. This is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Oct 10, 2012 | Hansgrohe Plumbing
I need a hansgrohe avate guard lav faucet aerator wrench?
The aerator on Hansgrohe Faucets generally do not require a special tools to remove them. They normally unscrew in a counter clockwise direction. Some specific models do require a tool.Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech. Ask for David Scarborough.
Jul 04, 2012 | Hansgrohe Plumbing
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
How do you remove the hot and cold taps on a shannon monobloc mixer tap, water is dripping from the cold tap
Use 2 Adjustable Wrenches . you may need a Allen key set to Remove the Mixer unit . You can fix the Water dripping problem may be replacing a O ring
Nov 18, 2010 | Plumbing
Hansgrohe Kitchen Faucet low water pressure
Try removing the aerator and handspray to clean out any debris that may have accumulated. After 8 years there could be quite a buildup if it hasn't been regularly cleaned.
May 24, 2010 | Plumbing
Hansgrohe concealed thermostatic mixer ref no 1537418
check for sediment in your valve body... sometimes sediment can build up particularly in hot water pipes and that can cause the pressure balancing function of the valve to limit total hot water and therefore you cant get it hot enough... here is a link to what I think is the proper valve and the instructions for installing it... you'll want to follow the instructions for flushing and pressure testing... if you have good pressure at the thermo body then you might try adjusting the hot limit stop also covered in the document linked below...
http://www.hansgrohe-usa.com/JP/hrgh0264.pdf
Hope theat helps...
Oct 25, 2008 | Hansgrohe Plumbing
Hansgrohe 06358620 Pressure Balance Valve w/ Scroll Handle Oil Rub Bronze Logo
32 people viewed this question
Top Hansgrohe Plumbing Experts
GCcontractor
Jim Goldsmith
Jim Goldsmith
Andrew Bugbee
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
