Question about RCA 5-cd 300w Stereo System Shelf System
Pioneer CLD 990 Player
I opened my player up and watched the disc go in,,then it loads ,then it spins,,but it spins like its jumped off track ,,so to speak,,then the machine stops and the tray brings the disc back out..its like the disk is not being held down firmly as it starts to spin and the machine reads this and stops,, bringing the disk back out ....what is causing the disk to start to spin out of control,,it does not look like anything is broken??
  • skutterbug20 May 20, 2009
    i have 7 day return on it so im just going to bring it back to the store i bought it from
  • Anonymous May 21, 2009
    i opened it up and got it to eventually play a disc,,,the problem is it will not clamp correctly,,so i have to pull the disc a little until the clamp is centered on the center of the disc..is this some kind of belt issue?
  • 65 Answers
It is out of postion all u can do is take it apart and try to re postion the laser arm ur self other wise sell the item on ebay
Posted on May 18, 2009
Pioneer cld 2950
The disc drive may be unable to read the disc and ejects it.
Jan 20, 2014 | Sherwood Audio Players & Recorders
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
May 10, 2011 | Pioneer DV-717 DVD Player
I have a Pioneer cld-v860 with an error code ho. can you tell me what it is?
Pioneer CLD-V860 is an old model laser disc player and you need to have service manual copy to get error code details as we do not have related service manual copy.
Required service manual copy can be downloaded from HERE for small fee and service manual has all technical info about this unit, schematics, troubleshooting chart, part numbers etc.
Hope this info will help you.
Thanks.
Sep 21, 2010 | Audio Players & Recorders
Pioneer CLD-95 only spins laserdiscs when it feels like it
It sounds like the read head assembly is not resetting back to the starting point so it can start off reading the "A" side of the next disc. Probably turning it off and then on resets it back to the start of the "A" side. You might try flipping the disc manually to the "B" side, let it go and then try another disc to see if it works.
Mar 30, 2010 | Televison & Video
My Pioneer CLD-990 only plays through one side of
One of the common causes is a small crack in the ribbon cable that connects the optics assembly to the PC board. This cable is moved all the time when the optics move and when the assembly turns over. This is not a repair I would recommend to a novice. The cable is still available last time I checked and is simple to replace for anyone that has worked on these before. The tray must be removed to do this and it is tricky to re-align properly. I think the cable runs between $20-$30.
Dan
Mar 18, 2009 | Televison & Video
2002 lincoln alpine 6 disc focus error
Probably a Sony clone. Have a look at the Pioneer disc player schematics.
May 22, 2017 | Car Audio & Video
Laser disc player produces b&w only lately? pioneer cld-d504
Ooops, in my efforts to find laser disc INFO I ended up in a completely irrelevant category; because there no longer exists a Laser Disc category. So I shall abandon the laser disc player as technologically obsolete (there goes still another species of dinosaur off to the fossil beds) and give up on seeing those movies in color.
Nov 08, 2008 | Pioneer Computers & Internet
The "no disc" message will show up any time the unit tries to play a disc and fails. This can be because the lens is dirty or the optics have failed. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics are failing and will need to be replaced.
Dan
Jul 29, 2008 | RCA 5-cd 300w Stereo System Shelf System
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
150 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
