Question about Konica Minolta Magicolor 4695MF All-In-One Laser Printer
Error code: Machine trouble, service call code 1038
How can this be repaired without calling the service technician?
  • Konica Minolta Master
  • 6,696 Answers
One of your printer control boards are bad or loose connection
Posted on Jul 04, 2016
firecontrol7
  • 6696 Answers
SOURCE: Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Posted on Jul 19, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
taminol
  • 62 Answers
SOURCE: my brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Posted on Apr 26, 2010
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Posted on May 11, 2010
xeerie
  • 347 Answers
SOURCE: my bizhub 210 is coming up with an error mesage
its the code of ATDC sensor, that means your machine is having low deveolper, kindly change the developer to permanently get rid of this code. thanx
Posted on Jun 19, 2010
Ricoh sp 210su service call sc559 problem
Code
SC559
Description
Fusing Unit Third Jam Error (Fatal Error)
Causes
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
Remedy
• After this error has occurred three times, the machine will shut down automatically and cannot be re-started until the machine has been serviced by a service technician. • Check the paper transport path for any physical obstructions (paper scraps, etc.) • Make sure the fusing unit has been installed correctly • After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
Apr 10, 2018 | Office Equipment & Supplies
Kyocera km 2540 error code C6150
Refers to an Abnormally low fuser thermistor edge temperature. Your machine could not warmup. Fixing error codes (C6xxx series) must be reset by a technician after clearing the cause of trouble. Reseting a fixing code without proper repair may result in fire or damage.
Sep 04, 2014 | Office Equipment & Supplies
C 1038
Open the front door, up left small access cover remove and push trouble reset button. Once reset the malfunction and turn OFF and ON the Power Switch. If the same malfunction is still detected, check cables for proper connection and, if they are okay, change PWB-B. If you can find one, quite old machine, a legacy Minolta, now Konica MInolta
Mar 04, 2013 | Genuine Konica Minolta Konica Minolta Di...
Error code e2 on Rheem tankless water heater
e2 is not shown among common error codes:
Error e2 might be: Brownout condition or too low of voltage to thermostat. Double check wiring and check for 24 vac between R and C. E2 will clear 15 sec after proper voltage is restored.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat and typical generic manuals and common error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Model number and serial number are required for Rheem contact, and then they tell you what error code means without saying how to fix it, and then tell you to call service technician.
Tankless water heater manuals each say to have qualified technician perform yearly service. Most causes for common error codes are covered by yearly service.
Yearly service is fairly standard in the HVAC and water heater industry with advancement of high-tech 'energy' saving appliances. Of course all costs are energy, and the service call probably costs more that the 'energy' saved by energy-saving appliance. But with high tech stuff like tankless, it is good to have a reliable service guy who knows your machine.
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Jul 27, 2011 | Rheem Tankless Hot Water Heater...
We have enjoyed a Rheem Thermostat and a Paloma Eco Sense tankless gas water heater #RTG-74XN-2 for 2 and 1/2 years, but now there are error codes flashing and resetting the thermostat doesn't hold. ...
Before calling service technician, open following links for Rheem troubleshooting resources, including generic error codes and contact information for Rheem and recent manuals:
http://www.fixya.com/tags/rtg_74pvn
Error codes are start place for troubleshoot, and multiple error codes can indicate bad PC board.
Same error code on one machine can be different cause and solution than another machine.
Error 76 is usually communication problem with remote control.
Disconnect wires from machine, and clean terminals is a start point.
Wire between machine and remote might be bad, or remote control is bad, or PC board or wiring connections are bad.
The problem might be solved by having technician catch the machine up on yearly maintenance.
Manual for same-similar product shows maintenance and troubleshooting and a few error codes, but not 76:
For the most part, the manual recommends calling service technician instead of offering DIY details.
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
SHARP AL-1665CS SYSTEM ERROR H4-00. DON'T HAVE THE MANUAL WHAT IS THE ERROR? wHAT DO I NEED TO DO TO FIX IT?
This error indicates a problem with the fuser on the machine. You will need to replace the fuser unit and reset the code. The fuser is fairly simple to get out, you will need to remove the back cover and the jam access door on the right side of the machine. At that point, the fuser is simply held in with three screws and a connector.
To reset the code you have to go into service mode by pressing this sequence of keys ("C" -> "Exposure" -> "C" -> "Exposure"). You will need to press them fairly quickly, about a second between each press, and confidently. You will know you are in service mode because the display will change to "--" and flash. At this point, enter "14" as though you were making 14 copies, and press the green start button, then press the "CA" key to exit service mode. The machine will begin restarting itself and if the problem is resolved it will come to ready.
These machines were notorious for giving H4 errors randomly and without a real reason, so I would suggest that you try resetting the code one time before calling it in for service. If the code comes back after you reset it once, or comes back on a fairly regular basis (meaning more often than once a month), I highly recommend calling a professional repair technician in for service.
Feb 28, 2011 | Sharp AL-1655CS Copier
Can the machine still fixable when it just flashes ERROR light and the note that says: CAUTION Machine trouble. Service call (102H). What do I need to do?
Telephone the nearest KONICA MINOLTA store, and ask for a service-call, i.e., a technician to come and fix your printer.
Oct 05, 2010 | Konica Minolta magicolor 2480 MF...
Samsung washing machine error code te?
The problem could be the thermistor, but before you replace it, check the wiring. Many people with this error code have found one or more broken wires. If you call for service, be sure the technician checks the wires.
Jul 01, 2009 | Samsung Washing Machines
Konica Minolta Magicolor 4695MF All-In-One Laser Printer Logo
105 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
