Question about Sony PlayStation 2 (PS2) Console
Always says disc error
My ps2 says "read disc error" all the time!!!
  • Anonymous May 25, 2009
    how do i clean the laser?
  • penguinpitt May 25, 2009
    Is the disc error message always related to a problem with the console, or could it also be caused by a bad disc?
    President:
  • 2,653 Answers
Dirty laser, or bad laser all together.
First step would be to clean the laser with a dry q-tip.
If that doesn't work then you'll have to replace the laser.
That's pretty much it.
Best of luck!
Posted on May 18, 2009
I have a Playstation that always says "disc ead error"
This is probably a result because somehow the discs got scratched, or are dirty. This could of happened by moving the console with a disc in it, or maybe just touching the "silver" part of the disc. Or, this may be happening because the reading device of this console is a little dirty, or it could just be a internal error
Jan 21, 2013 | Sony PlayStation 2 (PS2) Console
My PS2 always shows disc read error on all discs, what can I do
What you need to do is take you ps2 apart and clean it out and clean the laser lens that reads the cd's...you should be able to google ps2 disc read errors and get videos to help you through it.
Dec 13, 2009 | Sony PlayStation 2 (PS2) Console
Gta san andreas loads but then says error reading disc
if you are using the older style ps2 fat one then its probly that the disc might either be scratched a bit and almost outta date as a older ps2 gets used it will begin to have disc reading errors what i did was upgrade to the slim they have less problems with disck reading erros over time id do one of two things or both take the disc to someone or a place to have it professionly cleaned for at most 3 bucks then try it then if not try leaning your ps2 upright and incert the disc some times doing that will make the laser not hickup and read it better with the motor running sideways keepng it from skipping . if it dosnt help much im sorry but its always a good try ;)
Apr 30, 2009 | Sony PlayStation 2 (PS2) Console
Please insert ps2 format disc?
Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
Mar 05, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 disk read error
THE LASER LENS AND OR HUB SURFACE is dirty
Dec 05, 2008 | Sony PlayStation 2 (PS2) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Disc Read Error ( slim PS2)
Ah yes the dreaded DRE... time to replace your ps2 dude, this is the easiest and least headache solution.
Logged too many hours on those poor machines ;)
Aug 18, 2008 | Sony PlayStation 2 (PS2) Console
PS2 disc read error. Help Please
my skinny ps2 will not read the disc
1. it takes long
2. it says disc cant be read
Apr 06, 2008 | Sony PlayStation 2 (PS2) Compact System...
PS2 Disc Read Error
You should buy a replacement dvd drive for the ps2 , for about 25.00 USD on ebay, it is easy to install considering you already have taken apart the ps2
Aug 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
