Question about Garden
My riding mower is stuck in gear. I can shift
My riding mower is stuck in gear. I can shift without the clutch pushed in, and it's stuck in gear. When I push the mower, the wheels stay locked. I can start the mower, but when I push the clutch in and let it out,it makes noises. Is this something a mechanic will have to look at? I worry something is wrong with the transmission. It seems the rear wheels aren't both facing forward the same, one seems twisted a bit.
    Sniper:
  • 57 Answers
If the wheels aren't facing straight forward you may have broken an axle.
Posted on May 18, 2009
Our 7366SS WAS IN 3RD GEAR AT IT JUST QUIT PULLING WOULD THAT BE THE CLUTCH ?
If it's belt drive I would guess you're belt broke or just jumped off pulley
Mar 05, 2015 | Garden
How do I get my riding lawn mower to shift into gear?
sheared the keyway in the trans have to replace it a woodruff key is what you need
Oct 03, 2014 | Garden
How to fix Stuck in reverse Clutch is Fine.?
Have you tried checking the linkage to the hydrostat/transmission? Are you getting full movement of the lever? If not, it might have just come loose and shifted so you only have reverse. If you have full movement of the lever and the hydrostat has the proper amount of fluid it could be fried. It's hard to tell without diagnosing the linkage. I'd suggest blocking the rear wheels off the ground so you don't run over yourself before you go messing with the linkage.
May 14, 2014 | John Deere 22HP VTwin Hydrostatic 42"...
How to fix John Deere 4600 stuck in reverse can't shift to forward gears?
The transmission/rear end will have to be taken apart. Most likely the keyway has broken and the gear is stuck in place.
May 14, 2014 | Garden
Car stuck in first gear wont shift at all
Suspect the clutch is frozen and even when you press the pedal it does not disengage. If it shifts into other gears without the engine running. you will need to break the clutch free. Put it is high gear with the clutch depressed and rock the car back and forth with a bunch of friends pushing on it.
Apr 01, 2014 | Chrysler Sebring Cars & Trucks
Gear selector is sticing hard nto change gears
What model? May need adjust clutch a little. Or adjust gear shift linkage a little too.
Mar 27, 2014 | Garden
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Mar 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
733 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
