Question about Krups XP4030 Espresso Machine
Water runs down not going intopot on initial first use try out
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
State Water heater pushed button to turn water down - all lights were lit initially.now no hot water - tried to reset - not resetting - help!
Which water heater do you have?
Is this gas or electric, tank or tankless?
What button did you push to turn water down??
Do you mean turn down water temperature?
What lights do you have that are lighting up?
Aug 11, 2012 | Water Heaters
Not starting after being washed. Initial start on choke ran, then stopped after choke closed. Did this three times. Also have oil dripping out after this from start of exhaust.
Did you get water down the exhaust pipe???
Take the spark plug out,clean it and put it back in.The oil coming out the pipe may be soot and water mixed together.Try this and see how you go
Apr 20, 2011 | KTM SX 200 Motorcycles
Water won't fill
it's syphoning caused by the drain hose in the stand pipe (wall) too far.
pull the drain hose out and stick in 6 inches only and secure to one of the fill hoses so it does not go back down too far. This will solve your problem
Apr 05, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Aug 01, 2009 | Kohler Home
Broken impeller part ?
Keep in mind that the head rate for this pump has been calculated at about 3 1//2 ft high. If you try to go to the garage roof you will exceed the head rate and extremly so if the garage is not on top of the pool and cause your motor to overheat due to it trying to pump the heavy water past its capacity
It would initially work but burn up sooner than later
you woul be better off building a solar type box with plexi glass and wrapping x amount of feet of smaller diameter black hose.
You will need to t down ( on the inlet and outlet ) your pool hose to the smaller one so that the water will slow down inside the box to accumulate the suns rays At no time should you exceed the height restriction
Jul 10, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont run
Try using the spin only function with some water in. To see if it runs, & to wake up the machine.....
Aug 19, 2006 | Maytag Neptune MAH5500B Front Load Washer
Krups XP4030 Espresso Machine Logo
22 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
