Question about Philips Senseo HD7832 Coffee Maker
Lid won't close
When pod ius inserted u cannot close lid
Why won't lid close?
Hi,my friend had one of these and they sied that if the coffee pots are not inserted or they are the wrong ones his lid didnt close iver,hope this was some help.
Sep 17, 2016 | Braun Tassimo Espresso Machine/Coffee...
The water does not flow through the spout. Can this be fixed or is it cactus?
YOU MAY FIND CACTUS IN THE GARDEN BUT YOU COFFEE MAKER NEEDS TO BE CLEANED OUT TRY CLEANING THE SPOUT FROM OUT SIDE WITH A LONG NIDDLE LIKE TO CLEAN THE CHANNEL PLUS RUN SOME WORM WATER TO MELT IT DOWN
Nov 14, 2015 | Nespresso U D50 Espresso Machine with...
The lever wont close all the way after I insert pod?
You can move the handle slowly up and down until the coffee pod drops down. Be sure the used pod holder underneath is empty.
Mar 07, 2015 | Starbucks Single Serve Brewer, Verismo 580
Why wont lid on my phillips senseo hd7863 close when the pod is in the holder ?
Maybe you inserted the pod with the wrong side up or you used a 2-cup pod in a single cup holder. If the clamping spring isn't working (the lid feels loose when you try to close it), that spring (that is nothing more than a straight piece of metal wire) needs to be replaced.
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
Why lid wont close when pod is in holder ?
Did you place the lid in correct?
Is it the lid that came with the machine?
You should have two, one for one pad, and one for two pads. Make sure you only put in one at the time.
You can fine the manual online, but the most important pictures are here too e2d40f99-b185-43c6-bffd-a3c704f68e25.png
Lid won't close
Take the disc out, hold the disc holder down flat, then close the lid. Open up and will work as normal. If this works for you, please visit sun-light. co.uk
Dec 20, 2012 | Bosch Tassimo T20 Brewer Color Kit
I have a 96 jetta, and my trunk release button doesn't work. how do I fix it. Plus I put the key in the trunk to open it, its always worked, now it doesn't. I need my trunk, I have a small child...
The trunk release rod is made of plastic and it is adjustable, it came apart. You have to fold down the back seat, remove the trunk lid liner and pull on on the plastic piece connected to the latch mechanism on the deck lid. It is a little difficult but is the only way to get in. You can buy the plastic piece from V.W. its cheap. When you install the new piece, use a screw driver to close the latch and try to open it with your key fob or button, this way you won't shut it and not be able to open it because it is not adjusted properly. there should be very little play (movement) between pod and latch if adjusted correctly. The rod connects to a vacuum pod for the key fob to operate the trunk remotely. good driving
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | 1996 Volkswagen Jetta
Top will not unlock
It seems to be caused by pressure build up (not a vacuum) when the outlet of the pod holder gets blocked. There are three plastic bolts that slide into place to lock the lid as the lever is operated. Pressure forces the lid up and increases the friction on the bolts to the point where they won't operate. Solutions 1 and 2: First disconnect Senseo from the electric supply. Solution 1 is to press down on the lid to overcome the pressure and then operate the lever to unlock. Didn't work for me. Solution 2 is to get a table knife, not sharp, no serrations but with a rounded end, not pointed. Insert under lid just to right of pod holder handle, at an upwards angle of about 20 degrees to the horizontal. Then aim for the opposite 11 o'clock position on the closed lid. With a few tries the knife blade should slide between the top of the pod holder and the rubber sealing gasket releasing the pressure. Beware hot steam/water as pressure is released - wear gloves. Open lid, unblock pod holder hole with a pin, fill and heat resevoir and then flush through without a coffee pod in place.
May 21, 2010 | Philips Senseo HD-7810 Coffee Maker
Latch will not snap closed
Had the same problem.I fixed it by carefully prying the top lid apart,the latch had become detached from the slider inside.Simply snap the latch back onto the slider and snap lid assembly back together.Do all this unplugged with reservoir empty.
Dec 10, 2007 | Philips Senseo HD7832 Coffee Maker
Stuck senseo maker
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Oct 28, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD7832 Coffee Maker Logo
50 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
