Question about Philips HTS 6600/12 Home Theatre System HDMI Theater System
Tray won't eject dvd - Philips HTS 6600/12 Home Theatre System HDMI Theater System
How to fix continous toshiba cd eject problem
Hi Solomon,
Kindly check this site on how to deal with that issue. Hope it helps.
Laptop DVD Tray Won Eject How To Open CD Or DVD Drive
May 08, 2014 | Toshiba Computers & Internet
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
My Technika DVDr 2005 drawer will not open and has a DVD in place - how can I retrieve the DVD?
turn it off then unplug the dvdr then after a while plug it again and turn on, now press the play button after a while press the stop button then next is the eject button. if still the tray won't eject unplug the dvdr use a philip screw driver unscrew to open the cover. look for the plastic motor gear then manually turn it with your finger to eject the tray now you can get your dvd. place back the cover and plug the unit and then turn on to check if its working again and eject the tray. thanks i hope it will help you good luck.
Jun 13, 2011 | Televison & Video
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
May 21, 2011 | Toshiba 14DLV75 14 in. TV/DVD Combo
Philips HTS 6600/12 Home Theatre System HDMI Theater System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
