Question about Rinnai Heating & Cooling
Rinnai re-813 pms gas heater turns off after few minutes
  • 41 Answers
SOURCE: Rinnai Econoheat 850 gas heater
Hi Daryl,
It needs a service. The jets carbon up and when they heat up they stop the gas getting through. If you take it to a Gas Shop they will charge you around 90-00 to service it and all they will do is blow it out with compressed air. If you can get hold of an Air Compressor with an Air Blower on the end you can blow it out yourself. Remove the Gas Hose from the back and place the Air Blower into the hole where the gas goes through and hold down the ignitor switch to open up the jets. Give it a good blow out. Once you have done that give the candles a blow as they eget dirty also. You will see a white dust more than likely come out of them. If you want to give it a good clean out remove the cowling and clean (blow out) the inside of the Heater. The cowling from memory has only about 6 or 8 screws holding it on. That should take the top and sides off. I can't remember if you can remove the lower vent on that model - if so it will only be either 2 or 4 screws. Hope this Helps.
Regards
Bryan
Posted on Jun 21, 2008
  • 4 Answers
SOURCE: rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Posted on Feb 05, 2009
SOURCE: Rinnai 2001 Gas Heater - turn off
If, like me you have a Rinnai **** heater, with a PCB Assembly, then thats what the problem is. Look at around $500+ installation. These PCB's are not repairable. For $500, I am going to trash this heater and get something from a company that does not want to screw me after I have trusted them to live up to their "REPUTATION". Do not support companies that do not support their customers!
Posted on Oct 15, 2009
ftw1952
  • 10319 Answers
SOURCE: My Rinnai Spectrum 28 Gas
Most of these brands of heaters do not last more than 300 hours. if found to be operating fine most of the time I have found faulty gas regulators attached to the feed line to the valve causing the shutdown.
Posted on Apr 13, 2011
  • 4736 Answers
Other than a dust issue (clogged filter)., there are several things that could cause the unit to automatically shut OFF.
  • It's reached the temperature you have it set for and it automatically cycles to OFF.
  • The unit is overheating and the heater's overload switch is shutting it OFF.
  • The Flue may be clogged or partially clogged.
  • The flame failure device is faulty and needs to be cleaned or replaced
  • Low gas pressure.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. The manual should help you to continue to troubleshoot the problem.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/185.pdf
Hope this helped to solve the problem.
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
Extremely annoying humming sound coming from our rinnai RCE-318H gas heater. sounds like a bearing or wheel spinning noise. please help?
The humming you hear is from the gas pressure or lack there of. Check the inline gas shut off valve, to make sure it's fully open. If that checks out OK, turn the unit OFF completely and wait five minutes, before turning everything back ON and relighting the heater. If the noise is still there, contact your Rinnai dealer for a service call.
I hope this helped you, Arthur. Thanks for choosing FixYa. Cheers!
Aug 27, 2011 | Rinnai Heating & Cooling
My rinnai RE-613 PMS III gas heater has gas adjustment issues, the lower gas elements do not to properly become red hot as compared to the upper elements. Can you please guide me where I can make necessary...
yes waqar i can solve this problem,coz i am having this same model and the same problem,its a very easy process u can do it urself, in 10 minutes mail me at qasimmalik72@yahoo.com
Dec 11, 2010 | Rinnai Heating & Cooling
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
Its of automaticly after few minutes
Ok, so you have no heat. Make sure all shutoffs are on to the gas. There is one on the heater located on the right side under a little hinged door. Therer may be one outside at the tank or gas meter. Lets make sure we are getting gas. The Rinnai should make a few loud clicks when the gas valve opens. Are you hearing these?
Nov 06, 2009 | Rinnai Heating & Cooling
How to turn off lock button on gas heater
hold it for a few seconds till the light goes out
Jun 21, 2009 | Rinnai Heating & Cooling
Heating & Cooling Logo
124 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
