Question about Haier HDC1804TW Dishwasher
Will only drain not wash
My dishwasher will not start any wash cyckes it will only go into last drain and cut off
My mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
my mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
Aug 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
Intake/drain light flashes, and the diswasher won't start.
wash dishes by hand and use dishwasher for storage. lol
Oct 04, 2009 | Dishwashers
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
Dishwasher doesn't drain after washing
Try to see if you hear a slight hum noise from the electric motor under the bottom. The noise will not last for long. This is the motor trying to start in the reverse direction. For the unit to drain the motor must run in the opposite direction so it can actually wash dishes well in on direction and not run in the other. After power has been removed (and maybe water too) get under unit and see if motor will turn in both directions. If it does, then the nearby start capacitor needs replacing or the motor is defective. A bad motor will not hum for long before the "heat trip" safety device will cut it out and it will then have to cool off before more test or done
Mar 17, 2009 | Kenmore Dishwashers
The dishwasher fills with water and doesn't shut off at the start of the wash cycle.
I have a hotpoint dishwasher. I ran the dishwasher and it went through all the cycles but on the last drain cycle it didn't drain? Any suggestions
Oct 29, 2008 | Whirlpool Dishwashers
Not draining
the drain pump is separate from the was motor and is accesed from underneath the dishwasher that help wash moter is one piece and is replaced as a whole unit and the drain hose comes from the factory making a loop up side the tub a lot of installers cut the ties holding the loop to get more drain line if loop is removed will loose its prime and stop draining or drain some times and not others when you first start the dish washers it drains then fills so you should hear the drain pump rum if something isnt jamming it
Dec 30, 2007 | Frigidaire 24 in. PLD2850 Built-in...
ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Dec 06, 2007 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Open Questions:
Haier HDC1804TW Dishwasher Logo
29 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
