Fault code J50 & dark strip.
Turn on copier and after about 15 seconds it shows J50.
Copier also has a dark strip ,within which, letters double image (ie each letter repeats about 2mm from original). This dark strip is about three
quarters of the way down the page and and is about 70cm wide. This appeared right after I replaced the drum cleaning blade and before I cleaned the optics.
It neither had a dark patch nor was it double imaging before I replaced
the drum cleaning blade,before this, all it had was a striped line typical of a worn drum cleaning blade.
I then stopped the copier before the paper exited to check where the double imaging (and dark strip) was coming from. It was on the copy before it went through the heat rollers.
It was only after I had had the imaging unit in & out 3 or 4 times that
the J50 came up.
  • kevinhay May 18, 2009
    The copier is a Mita 1560 (old analogue) I put in the make & model
    in the space provided but obviously it did not transmit.
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    You get a "A+" with explaining your problem... But you left out the most important 2 things... Make & Model????
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
Posted on May 21, 2009
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
What does this error mean call service in kyocera copiers?
elle marche pas
elle signale une erreure est afiche code j50
a quoi signifi code j50
Feb 23, 2010 | Kyocera CS-2550 Black and White Copier
Copier/Printer Pproblem
what it means......
541 A Fusing thermistor open
The fusing temperature did not increase
12 °C at the center or ends of the hot
roller within 2 seconds after two checks
from the time the fusing lamps turned
on.
what could cause it.....
Fusing thermistor out of its position
because of incorrect installation
• Fusing thermistor disconnected or
defective
• Power supply not within rated range
(15% or more below rating
What to do if your not a technichian you should have one check it out
there are some high tempetues invoved ..the code is there to prevent fire hazzard
Jan 31, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Jun 19, 2009 | Ricoh Aficio 150 Copier
SHARP AL-1631 DIGITAL COPIER SHOWS ON THE SCREEN CODE H4 WHEN SWITCHED ON.
Hello sir; You do need following procedure to reset; once begun procedure must enter within four seconds; Press "clear", "exposue mode", "clear", "exposure mode" these 4 keys within 4 seconds, then enter 14, then press start, should take care the problem.
Jun 12, 2009 | Sharp AL 1631 Copier
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
Error code c26 on my Toshiba 550 copier
C-26 code it could be your exposure lamp.. when you turn on you copier keep the document feeder open and see if the lamp turns on...if it turns on and the turn off its ok.
Now clean your white reference guide..it's located under the glass..need to take off exposure glass and clean under it..especially a white strip on the edge of the glass.. NOTE: turn of your copier first then clean after adjustment turn on.
May 22, 2008 | Toshiba E-STUDIO 550 Copier
93 people viewed this question
k24674
jasbo
jasbo
